RichardN,
Never thought about copper pipe so been to measure some old 3/4in stuff. 21mm od so too big. And no it's not the new 22mm stuff. But thanks anyway.
Looked at the reference – rather expensive, roughly twice those from the usual suppliers.
SpeedyBuilder5,
On this particular project I've used: 100mm 3-jaw self-centring, 80mm 4 jaw independant, 160mm 4 jaw independant and 12mm MT3 collet. So I'm certainly not averse to using chucks, the major problem being the requirement to use a time consuming DTI to set up the work. A 15mm collet would have made life somewhat easier.
Jon,
No cutters are that size and you wouldn't want to use them MT3 collets in a lathe unless don't want them out again. Unless head stocks a small bore with MT3 up the spout you would need a draw bar making as well.
I find having the collets handy and quite useful at times as long as the work is the same size. Extracting is reasonably easy. Drawbar exists so no problem there.
Before I got the milling machine, I eventually found that the best, most reliable way of milling was indeed to hold the cutter in a collet in the lathe headstock.
Not being made of money, I deliberately bought my milling machine with MT3 so that I could use these collets in both machines.
Tailstock is MT2. Furthermore, my lathe has no provision for a tang to stop rotation. I have had to remove tangs on two adaptors yet ejection still occurs via the handwheel. I have never experienced slippage on the MT2 tapers yet I have had slippage between the drill chuck and drill bits.
Overall, I work in metric, and find the collets very useful. Any designs I do are always in metric. Often, I end up turning down to a collet size, and then I change to the collet for 2nd, 3rd etc operations where possible. A good example would be when using 6mm. I have a quantity of s/h free-cutting 1/4in stuff which tends to get initially turned down to 6mm in a chuck, then transferred to the 6mm collet and further turned down or drilled as necessary.
Probably the biggest, maybe the only, snag is that I can't hold long lengths of material, but for up to (guess) 75mm inside the collet, they are fine.
I think that when the present projects are finished, I might have a go at making one, just to see if I can. A quick glance at the 12mm collet shows that although it looks as if it is MT3 for the full length of the collet, in fact, only the gripping end, about 50mm or so, is going to engage with the inside of the mandrel. The rear portion, although tapered, is slightly less in diameter. Which means that I can turn it in two sections and thus it is within the travel of my topslide.
Thanks for the comments,
Peter G. Shaw
