Morse Taper 2 blanks
Home Forums General Questions Morse Taper 2 blanks
  • #398636
    derek hall 1
      @derekhall1
      Hi all,
      Rather than go to the hassle of setting up my top slide to a known MT2 to make an external MT2 using nice free cutting mild steel, I have obtained a supposedly soft blank MT2 arbor, because it might be quicker, easier and certainly more accurate.
      The problem is I need to machine down the "tail" of the external blank MT arbor and internal screw cut (1/2 inch x 32tpi) for a different draw bar thread. – well this is not really the problem, the problem is that the steel at this end of the arbor is tough – really tough….it is not easy to machine – actually almost impossible….HSS tools and drills struggle
      There are lots of suppliers who advertise MT blank arbors. So are there any genuine "soft" MT2 arbors that are soft throughout or are they only "soft" enough to machine at the large business end of the arbor?
      Regards to all
      Derek
      derek hall 1
        @derekhall1
        #398637
        John Haine
          @johnhaine32865
          Normally just the business end.
          #398640
          JohnF
            @johnf59703
            Look on the Myford site here **LINK**
            I used one recently to make an arbor for a milling cutter
            derek hall 1
              @derekhall1
              Wow thanks for the replies….10 mins after my post!
              This is why this website and forum is so good.
              Thanks guys…
              Derek
              #398651
              KWIL
                @kwil
                Make another drawbar to match is an alternative if nothing other is possible.
                #398662
                Howard Lewis
                  @howardlewis46836
                  The Blank Arbors that I got had M12 threads, so was able to make up a screw in adaptor to convert to 3/8 BSW, so did not need to machine the small end.
                  Probably only soft at the front end, with the part liable to wear being hardened, if only slightly. Any chance that you open up to tapping size with carbide tipped small boring bar?
                  #398664
                  Plasma
                    @plasma
                    +1 for making a threaded adaptor or new draw bar. I made threaded sleeves for my 30 int tooling so that I only have one draw var to worry about.
                    #398799
                    mechman48
                      @mechman48
                      Look here for similar…more reasonably priced ( usual disclaimer ) …
                      https://www.arceurotrade.co.uk/Catalogue/Blank-End-Arbors
                      George.
                      Edited By mechman48 on 05/03/2019 13:04:43
                      #398800
                      JohnF
                        @johnf59703
                        Posted by mechman48 on 05/03/2019 13:03:42:
                        George.
                        Agreed George there are many competitively priced units, it depends o what you are making of course but I find that many of them are too short to be of use hence my choice of the longer one at 2.0" , really a cannot see why suppliers don't have them longer the cost would be [should be !] negligible and "putting on tools" are rarer than hens teeth !
                        John.
                        #398847
                        John Olsen
                          @johnolsen79199
                          The morse taper blanks that I have had occasion to modify have been just surface hardened…probably nitrided. So a bit of a grind on the end to take off a millimeter or so, and then you are into material that you can drill and tap. This may not apply to all makes but it is worth a try, I have done it to more than one.
                          Howard Lewis
                            @howardlewis46836
                            Had a bad time yesterday. It took me four tries to make another M12 – 3/8 BSW adaptor, before I succeeded (the M12 kept shearing off before I reached full depth Probably because I was using commercial studding )
                            The successful ones have all been made from High tensile bolts /studs. Must be a moral there!
