Model Engine Gear Wheel Suppliers
Home Forums General Questions Model Engine Gear Wheel Suppliers
  • #23541
    ChrisH
      @chrish
      #166660
      ChrisH
        @chrish
        Can anyone suggest a supplier of spur gears and internal gears suitable for model engines please?
        I have looked at the HPC website but was wondering if there were any others suppliers around.
        Chris
        #166661
        Bazyle
          @bazyle
          Davall
          and I think they are agents for Boston Gear so an even wider choice if you can afford them.
          Edited By Bazyle on 16/10/2014 12:05:17
          #166662
            GMB Associates are also Boston distrubutors, Muffet Gears would be worth a look too though I mostly use HPC.
            This German supplier also came up on another forum as the model had their internal gears speified, you can buy their stuff via Amazon. Maedler
            Edited By JasonB on 16/10/2014 12:11:03
            #166665
            John Burridge
              @johnburridge26484
              The other firms that I have used for gears if I havn't made my own are Duval gears in Hartfield, WMH transmissions limited in Tamworth Staffordshire, and Relience gears.
              Most of these you can buy on-offs I would think and these days lots of the model engineering suppliers seem to keep gears in stock
              #166666
              John Burridge
                @johnburridge26484
                I also for got to add there are quite a few model engineering machinist that you can put your requirements to them and get a quote for gears that you might want.
                The other way is seeing if there is any other model which uses similar gears that one of the model engineering suppliers keeps that gear in stock.
                It worth looking on the net and on Ebay.
                #166668
                John Burridge
                  @johnburridge26484
                  The other person I use is John Ward Tel No 01282-869262 and web page http://WWW.latheparts.co.uk as well as his parts and accessoreies for old and obsolete lathes and mills he can make most gears out of most materials,spurs,helicals,bevels,and worm and wheels all at reasonable prices.
                  #166690
                  Bob Brown 1
                    @bobbrown1
                    Here's another **LINK**
                    #166697
                    thomas oliver 2
                      @thomasoliver2
                      S.H.Muffett – very high quality gears.
                      #166698
                      ChrisH
                        @chrish
                        Thanks for leads chaps – certainly have some more to go at now!
