ml7 setup
ml7 setup
Home › Forums › Beginners questions › ml7 setup
Viewing 2 posts - 1 through 2 (of 2 total)
  • #6200
    paul rayner
      @paulrayner36054
      #92727
      paul rayner
        @paulrayner36054
        hello everyone another newbie here, just a quick couple of questions thats niggling me
        ive bought an ml7 and setting it up, got the bed level, adjusted the gib strips as they seemed very slack with a bit of movement to me, ive also invested in an mt2 test bar, which ive put in the headstock and run a dti along it ontop and to the side which is 0.002" out on both planes from one end to the other.
        my questions are
        1) how tight should the carriage & slides be (i can push the saddle by hand but not the slides)
        2) is 0.002" out acceptable i would have thought is should be the same along the total length? will the bearings need adjusting to correct this? ( there is slight movement when the nose is forced with a bar 0.001&quot
        3) when i do rolly's dads method most posts state shimming head /tail stock for adjustment would it be acceptable to utilize the jacking nuts on the
        blocks? the reason i ask this is that there are no washers between the lathe and the riser blocks so not much to bed on.
        many thanks for any replys in advance.
        paul.
