ML7 lost drive
ML7 lost drive
Home Forums Manual machine tools ML7 lost drive
  • #364370
    AJW
      @ajw
      Using my ML7 this afternoon turning at a large diameter the chuck stopped. This is usually caused by the mandrel belt slipping as I don’t have it that tight, but it wasn’t, the belt/pulley was still being driven!
      It would appear that the stepped mandrel pulley drives the smaller (brass) gear I am guessing that there is an interference fit within which has now failed (been ok for the last 60 years!)
      Obviously a strip down is on the cards and I’m guessing the drive could be restored possibly with ‘loctite’?
      Anyone else encountered this problem?
      Alan
      AJW
        @ajw
        #364371
          Few similar posts like this one will help
          #364373
          AJW
            @ajw
            Thanks for that, it is as I suspected, no longer enough of an interference fit!
            Alan
            #364408
            John Olsen
              @johnolsen79199
              I had that happen on my ML7 some years back. It does not help that the standard V belts make the alloy pulley run quite hot. I ended up changing it over to a poly V belt. While I was about it I made a four step pulley instead of 3. Hemingways have a kit for ploy V belt to a Super 7 but that is not applicable for an ML7. Maybe I should write up what I did.
              AJW
                @ajw
                Thanks John, I agree the pulley does run warm and perhaps with the warmer weather it took it beyond the point of no return! I can still use it on ‘normal’ stuff but working on a 3 inch diameter highlighted the problem.
                Alan
                #365051
                AJW
                  @ajw
                  Dismantled the headstock today and had to heat the pulley to get it off the gear – it was still a good fit!
                  All cleaned up and degreased then assembled with Granville ‘bearing fit’
                  Seems to have done the job, time will tell!
                  Alan
