I've watched posts on the dewhirst switch with amusement, there's nothing wrong with them at all if you use them to switch the starting windings in the direction you want the motor to go, but switch the lathe on & off with your push button starter, & don't use it as your main switch to start up, as for starting & stopping single phase motors all the time[apart from the extra cost in electricity] I certainly don't do it, the students at the high school where I worked were all lined up waiting to use the belt sander & the teacher let them switch it on & off each student & sure enough eventually the motor failed & I had to fit a new motor, there was no clutch on my colchester student so I hinged the motor & made a swinging mechanism to use as a clutch[it's flat belt drive] my old edgewick lathe had the same drive, the only thing I do if I'm measuring the workpiece or touching the chuck is to simply put the high/low ratio lever in neutral so it's 100 percent disengaged.
