ML7 clutch
ML7 clutch
Home › Forums › Beginners questions › ML7 clutch
  • #271213
    John Smith 34
      @johnsmith34
      Can anyone supply a copy of the plans for the shop made clutch detailed in MEW No. 5?
      I will gladly repay all costs incurred.
      John S.
      #8430
      John Smith 34
        @johnsmith34
        Shop made Clutch
        #271233
        john fletcher 1
          @johnfletcher1
          Hello John S. If you send me a PM with your address I'll send you a copy. My friend and I made ourselves one each several years ago and both are still working. One thing I/we found was the clutch leather initially slipped a bit, then some one suggested we dribble a bit of Violin resin between the faces, after that, no problem. I can't remember the issue number but I have all the early ones with all the instruction in, so can find out. l will enclose a copy of that as well ,when I locate it . John
          #271361
          Brian Oldford
            @brianoldford70365
            The preceding posts raise interesting thoughts on the "best" material for clutches. I'm unsure what material the leather would be mated with but there's sure to be a difference between iron and steel. Oddly the clutch on the Mk1 Super 7 mates iron with iron. Any thoughts?
            #271381
              Posted by Brian Oldford on 12/12/2016 14:24:28:
              Going by the abysmal performance of a steel brake drum [on a Vincent Comet], compared to the iron ones, I would almost certainly choose iron.
