Ml7 apron handwheel
Ml7 apron handwheel
Home Forums Manual machine tools Ml7 apron handwheel
  • #104425
    michele bresciani
      @michelebresciani76304
      Hi guys. I need helpi’ve just bought a Myford Ml7 and i have a little problem: the apron handwheel has bit of play, what can i do?
      https://www.youtube.com/watch?v=Kyed68qGwOI&feature=youtube_gdata_player
      Check out the link, ive posted a video on you tube
      Thank you so much
      Michele
      michele bresciani
        #104439
        Bazyle
          @bazyle
          not sure from video but is it wobbling on the shaft ? as opposed to just having a bit of back lash?
          #104462
          michele bresciani
            I think there’s a clearance between the rack and pinion..is it possible to fix it? Maybe with a new pinion
            #104480
            Grizzly bear
              @grizzlybear
              Hi Michele, Welcome to the forum.
              As an ML7 owner myself, I'm sure Graham has identified your problem. Are you into model making?
              Regards Bear..
              #104484
              Gordon A
                @gordona
                Hi Michele,
                I had a problem with worn ML7 apron bushes and bought a replacement set from here.
                http://www.lathespares.co.uk/
                Gordon.
                #104511
                michele bresciani
                  Thank you so much guys, i’ve just bought a replacement set of apron bushes..hope it works..Grizzly, no i’m not really in model making, i’m into pipemaking
                  #104515
                  Grizzly bear
                    @grizzlybear
                    Pipes, would they be Pan Pipes or Smoking Pipes? Bears can be a bit nosey.
                    Regards Bear..
                    #104518
                    michele bresciani
                      Uilleann pipes, the irish bagpipes. Have you ever seen them?
                      Michele
                      #104519
                      John Stevenson 1
                        @johnstevenson1
                        Irish pipes ~?
                        Are they similar to Guiness bottles that have open other end on the base but in this case it's blow from tother end ? wink
                        #104522
                        Grizzly bear
                          @grizzlybear
                          Uilleann pipes, Interesting. Had a look on Youtube. This bear is not musical.
                          What will the main material be, just wondering if a wood turning lathe would have been a better option.
                          Regards Bear..
                          #104524
                          michele bresciani
                            The main material will be ebony. i bought a metal lathe so i can turn out reamers an the whole metal parts
