ML10 – ready for the boneyard?
Home Forums Workshop Tools and Tooling ML10 – ready for the boneyard?
Viewing 25 posts - 26 through 50 (of 105 total)
  • #364865
    Andrew Tinsley
      @andrewtinsley63637
      As I feared the memory isn't so good. The apron was modified to cope with the regrind, although I reckon bushing the lead screw brackets would have been simpler.
      Andrew.
        Posted by Roger Hart on 31/07/2018 14:45:20:
        … it would be interesting to know what the real options are for a regrind …
        That's what I thought, when I was considering buying a used ML10, Roger
        Unfortunately, I couldn't find any useful advice, except that document by Mr. Moore.
        It's a pity they didn't build it with a replaceable bed-plate,
        like the Hardinge DV/ DSM-59
        Edited By Michael Gilligan on 31/07/2018 17:03:28
        #364872
        Martin of Wick
          @martinofwick
          Posted by Mick B1 on 31/07/2018 14:09:26:
          Posted by Martin of Wick on 31/07/2018 13:04:05:
          I have a fitting for turning diameters up to about 11in, cant remember when I last used it though!
          How does that work? Riser blocks for the headstock? Workholding on the ar$e-end of the spindle? I never found any such device when I was building my Stuart Beam.
          Mick see link above and find machine builder post with video and scroll to near end of video to see what these devices look like. Don't think they are available as commercial products, but basically they consist of a billet of material which can be clamped to the bed in which a short spindle runs on bearings, a Myford nose one end, myford change wheel(s) other end – spindle at a suitable distance above headstock spindle, driven by a morse taper with another suitable change wheel. As these are DIY items, a great deal of variation may exist eg. fabricated frames, timing pulleys and belts instead of change wheels etc etc. The max size is dictated by available tool positioning on cross slide
          The one I have for the 10 is change wheel driven, and has a layshaft with idler to ensure normal rotation, it is also geared down to approx. 1/2 headstock speed (remember the days before VFD and reversing switches )
          The one I have for the 7 is an absolute monster, using the kind of timing gears a tank would have and will spin you 13inches in diameter, should you feel so inclined.
          Both home made, the one for the 10 worked very well – I thought with the slop from the gears it would be very chattery, but not so
          I have never tried the one for the 7 in anger other than to confirm it runs ok (and as you would expect much quieter than the geared version). The body is an humungous solid iron casting taking a real effort of will to lift!
          They were both acquired, the one for the 10 looking as if it may have been built a plan, the one for the 7 looks as if it was constructed in a locomotive workshop of brobdinagian proportions.
          Personally, I see no good reason why you couldn't get a couple of reasonable regrinds from a 10 bed and of course you would also need to grind the apron top or the carriage bottom in proportion to respect the leadscrew nut position. But you couldn't do too many without thinning the V ways and then having grind the bottoms off tailstock and carriage Vs etc etc.
          Grinding the top of the apron must be way easier than drilling and eccentrically bushing the bed casting leadscrew bearings on a 10 … Full hero points for anyone attempting that!.
          The 10 is a lathe clearly designed by a committee of engineers and probably treated by its creator as the illegitimate brother of the 7, I suspect they felt the need to market something cheaper than a 7, but not something that would dent sales of the 7, hence its general quirkiness (as in why did/didn't the do that..? what can we do to make it not appeal to a mass market?). Highly under-rated machines, stigmatised by their lack of ubiquity.
          #364877
          larry phelan 1
            @larryphelan1
            If you want to do work,buy a lathe. If you want to play around,you have a great starting point.
            Simple as that !!
            #364878
            Ignatz
              @ignatz
              Larry, you make a lot of sense. smiley
              #364885
              Mick B1
                @mickb1
                Posted by Martin of Wick on 31/07/2018 17:13:17:
                Thank you for that. I don't think I've ever seen one of those attachments for sale separate from the lathe, which means they're effectively unobtainable except by making one, and IMO you really gotta love your Myford 10 to be prepared to do that. Bit like a whole skipjack tuna to catch a mackerel.
                I've said often enough that I ran a Speed 10 for 15 years and that I enjoyed it at the time. It could produce work as accurate as I could and it was for the most part smooth and pleasant to use. If I'd been able to afford the space and cash I might've kept it when I got my Warco. But for me there's no getting round the fact that the Warco can do a much wider range of work, both turning and milling/drilling, and is similarly pleasurable to use once you get it adjusted. I wouldn't go back now.
                I think what we have here may reflect the difference of emphasis between ME and MEW?
                #364901
                Ignatz
                  @ignatz
                  Just had time for one test before shutting down in the garage for the night.
                  I spent some quality time grinding and honing a fresh HSS bit – sharp as sharp.
                  Put that chunk of scrap steel rod in the 3-jaw chuck and ran a few short cuts, ending up with a skim cut of .001 inch.
                  The surface finish didn't look too bad, but the actual measured results are not encouraging. Over a distance of 3.5 cm the micrometer gave me the following (these being measured from the tailstock end, progressively closer to the chuck):
                  >> 15.212mm – 15.165mm – 15.135mm – 15.125mm
                  Not exactly parallel. sad  …er, I mean cylindrical.
                  Edited By Ignatz on 31/07/2018 21:04:04
                  Edited By Ignatz on 31/07/2018 21:04:39
                  #364907
                  Redsetter
                    @redsetter
                    As you seem to have convinced yourself its a scrapper, you had better scrap it. I will be very happy to come and take it away free of charge.
                    #364910
                    not done it yet
                      @notdoneityet
                      Do you live in Belgium, too? You won’t bring it home in carry-on luggage!smiley
                      #364921
                      Martin of Wick
                        @martinofwick
                        Uh huh….
                        A not untypical problem and hinted at my earlier post. Easily checked and usually easily fixed. I will take it from the top. the error is relatively large over the small distance – circa 3.5 thou and could be due to a number of simple adjustment issues….
                        First off and easiest, did you turn using the top slide or leadscrew? if using the topslide, did you check motion was 100% parallel to bed? if not set the topslide angle to be parallel to bed with using your DTI and see if that has any effect.
                        If you used the leadscrew to drive the carriage, then next thing to check is spindle alignment with lathebed/carriage. Various ways in which you can do this, easiest is with an MT2 test bar of reasonable length-say 6 inches, but you can also use a piece of silver steel in the chuck and the RDM (consult web for various approaches and rollies dads method is popular- google only problem with RDM method is that it may be telling you more about your chuck than the spindle, check out a steve Jordan video on alignment on youtube
                        If the spindle is miss-aligned, the headstock is only held by two clamps, it is possible that the headstock has had a knock or been interfered with in the past, this is trivial to readjust using the test bar (might need a shim or just re-setting to front Vway.
                        If checking with test bar indicates the spindle is true to the bed in all dimensions, then there are 2 other possible sources of non conformity
                        The easy- the chuck and or chuck back plate is distorted – no really, I didn't believe this could happen, but another member gave me the heads up on this when I was having problems with run out and it was exactly the cause of the problem. – check for no run out in the Y plane with DTI on the back of chuck mounting plate ( I will assume that the chuck jaws have not been modified by grinding etc)
                        If no errors found from all of above, check jaw alignment with piece of silver steel, if bad consider new chuck, if bold consider grinding chuck, if rich, consider replacing jaws (assuming they are available).
                        The difficult – the bed may be twisted – not that likely as the 10 has a very rigid bed compared to the 7 but it is possible that there has been distortion over time. arrangements. Check by turning a 6" x 1" work piece to a dumbbell shape and than take a LIGHT test cut at each end on the same setting and mic any twist will show up as a dimensional difference between the two ends ( refer you to Steve Jordan video for simple explanation) Quite what you will do about any twist depends on your method of lathe mounting – clearly you should not perform this test until all of the previous sources of potential error have been eliminated.
                        Could be that the gross error is due to accumulation of all of the above, so best blow the dust of the DTI and settle down to have a bit of sport.
                        All of these are simple set up checks and issues – even on new machines, welcome to the world of hobby engineering!
                        If non of these checks reveal any source of error, then your lathe has clearly been possessed by demons and should be handed immediately to an experienced lathe exorcist such as myself for safe keepingdevil
                        #364924
                        Martin of Wick
                          @martinofwick
                          Posted by Mick B1 on 31/07/2018 18:28:34:
                          Thank you for that. I don't think I've ever seen one of those attachments for sale separate from the lathe, which means they're effectively unobtainable except by making one, and IMO you really gotta love your Myford 10 to be prepared to do that. ?
                          agreed, I don't think I would have had the courage to make one, but they do appear from time to time on a popular auction site and are not always recognised for what they are (ie don't get bid up to stupid money like most myford stuff). The one for the 10 cost me about £30 plus about 10 for postage which is les than half what it would have cost to make. It is based on a solid aluminium billet, so not as cool looking as the one demonstrated by Myford Boy – King of Kasting, although I was somewhat alarmed to see that he double clamps it to underneath the lathe bed – do I need to fear that the awesome, stump pulling power of my 50 year old1/4 HP motor will tear the fitting right off the bed Vways?
                          any advice welcomed.
                          #364931
                          Ignatz
                            @ignatz
                            Martin,
                            Lots of food for thought in what you suggest.
                            The test was run using the leadscrew.
                            The 3-jaw chuck I used is an older Pratt Burnerd that came with the lathe when I bought it. The screw mount is integral with the chuck body and so I tend to discount faceplate distortion. The threaded mount is really snug (have to engage back gear to screw or unscrew the thing), seats quite well on the spindle and the jaws’grip on the workpiece quite secure. In any case, once the initial cuts are made, the surface of the workpiece should be – in theory – spinning true, in line with the axis of the spindle. However, I grant you that if I were trying to work on a piece of stock which was already (supposedly) round and true and I wished to machine it further then the accuracy of the chuck as concerns mounting, bell-mouthing of jaws and runout would be major factors.
                            “Rollie's Dad's Method of Lathe Alignment” is quite interesting. Thank you for that, sir. I found the article and have downloaded it. Very interesting! I shall attempt the test(s) as outlined. I sees yet further ‘quality time’ with the DTI in my near future.
                            #364932
                              Posted by Michael Gilligan on 31/07/2018 16:51:31:
                              As the ML10 was Myford's 'budget' machine I suspect they weren't planning to compete with Hardinge
                              #364933
                              Russell Eberhardt
                                @russelleberhardt48058
                                From your latest test you are turning a conical shape. That is most likely caused by the spindle not being correctly aligned with the bed. Forget about problems with the chuck. A badly fitted or eccentric chuck will still turn parallel.
                                Russell
                                #364934
                                  Posted by Neil Wyatt on 01/08/2018 08:56:17:
                                  Clearly, Neil
                                  Subtlety of wording : I did NOT mention anything about competing with Hardinge, I simply highlighted one feature of the DV/DSM lathes which would have been of great advantage to Myford ML10 customers, and might have added only a modest incremental cost if it had been engineered into the design.
                                  angel MichaelG.
                                  #364938
                                  Martin of Wick
                                    @martinofwick
                                    Ignatz
                                    Ha ha!, never trust a chuck! or rather 'trust, but check' as they used to say in the NKVD!
                                    I have exactly the same myford integral chuck, was having similar problems and the spindle checked as parallel on my 10 and so assumed there was some issue with the chuck jaws. I consulted the forum with view to grinding and somebody suggested I check the runout on the chuck back (nah, surely not , I thought) and guess what…. when measured- nearly 2 thou runout, which over the chuck + test piece length was 6 to 8 thou taper! (and would be correspondingly more for a longer piece).
                                    I think this type of chuck condition is unusual but not without precedent – anyway will only take 5m to check (somebody suggested internal stress relief over time as a cause of distortion, but I think more likely to have been die to a nasty lock up ). BTW, I did a quick and dirty fix of shimming up the low side between the integral plate and chuck bodywith some ally foil to avoid having to skim the integral plate and chuck innards – reducing the angular error to practically zero over 6 inches Picture of dismantled chuck in my album). There was still 1.5 thou runout in the chuck, but this is coaxial with the lathe and not worth chasing down on a 3 jaw
                                    Yes, but if your spindle or chuck or both are not coaxial with the lathe bed and traverse of the carriage, you will turn a taper as it appears is happening. Assuming you mounted the work piece perfectly axial to the spindle and your first measurement (the largest) is at the tailstock, your measurements suggest that the misalignment is towards the back right of the lathe (or the right end of the lathe may be twisted towards the back with respect to the headstock end). In respect of bed twist, the error seems too large to be fully accounted for by twist alone, but may contribute as errors can be cumulative.
                                    Yes, but bear in mind its limitations, in that with a chucked system, the method does not discriminate the error between chuck and spindle, which is why it is important to confirm there is no chuck runout (and that the jaws faces are co axial) – you do get people that grind the jaws in response to these type of issues without fully understanding the true source of error thereby not only not fixing the issue, but trashing a chuck as well (however, there may be perfectly respectable reasons to grind the jaws, but depends how well it is done)
                                    I would strongly advise you to get a 2mt test bar, it is a very useful bit of kit for checking spindles, setting tailstocks and topslides etc a 6in one will do but if you are masochist, get a longer one! If you put a quality test bar in a well cleaned and deburred spindle and it indicates true or not, then the result is usually definitive (and a piece of 20mm silver steel for other checks).
                                    Don't discount the possibility of bed twist, but that check should come after you have investigated all the other sources of error.
                                    Above all have fun!
                                    #364941
                                    Hopper
                                      @hopper
                                      Regardless of Rollie's great-uncle and precision ground test bars and the like, the ultimate test is exactly what you have been doing: Turn a test piece and measure it for parallel.
                                      All the rest is theoretical. The turning test gives you the real result of what a worn lathe will do under working loads and stresses with accumulative error from a chain of worn components.
                                      The other methods are best used when reconditioning a machine that is stripped down and unable to be operated at the time. But upon final assembly, a turning test is normally done and the final adjustments are made. As your lathe is useable, i would go ahead as you are, turning test pieces.
                                      A 1" diameter piece sticking out the chuck by 4 to 6 inches is ideal. To save a bit of time, rough turn the mid section – three inches out of four, or five inches out of six – to .050" or so smaller than the ends. Then you can just take fine cuts over the two end sections at fine feed to get your readings.
                                      If you can get it down to .001" per six inches you will be doing exceptionally well on an old machine. And that is plenty close enough for most home shop work. (Factory tolerance was max of .0008" per six inch test piece.) A bit of emery paper rubbed over the spinning job will remove that in seconds if the job is that critical.
                                      Edited By Hopper on 01/08/2018 10:15:05
                                      #364942
                                      Ignatz
                                        @ignatz
                                        Martin, I will this further advice into consideration. Thank you.
                                        #364952
                                        Ignatz
                                          @ignatz
                                          Hopper,
                                          Also good advice. Time for me to place an order for some clean turning stock to run some (better) tests.
                                          #364961
                                          Hopper
                                            @hopper
                                            Martin, chuck runout has no bearing on the test piece once a cut has been taken over it. Even if the chuck is off centre and cock-eyed, the turned surface of the test piece will be in line with the lathe spindle. And if the lathe is correctly aligned, that surface will be parallel end-to-end.
                                            If you take a piece of bar and mount it .050" off centre in the four jaw chuck, then take a .055" cut along it, the resulting cylinder will be in line with the spindle. Likewise if the bar (or chuck) is mounted at a slight angle.
                                            #364968
                                            Ignatz
                                              @ignatz
                                              For what it is worth I'm measuring 0.03mm ( = 0.0011 inch ) of runout on the back of the 3-jaw chuck.
                                              Other tests will have to wait. Need to order some turning stick and perhaps a length or two of silver steel.
                                              #364971
                                              Hopper
                                                @hopper
                                                That runout is well within tolerance for a chuck body. No problem there at all.
                                                One common problem with those old Burnerd chucks is bellmouthing of the jaws, which can lead to some tricky results, including poor finish and tapered turning and uneven turning as the job moves about while the cut is taken.
                                                If you gently grip a piece of silver steel, or a good quality socket wrench etc, that is a good cylindrical shape, in the jaws, you can often see a gap at the front of the jaws if they are bellmouthed. With a longer piece of bar you may even be able to grip it gently then grab the end and move it about quite a bit.
                                                There was an article in MEW about three issues ago on diagnosing and regrinding these old chucks.
                                                #364994
                                                Ignatz
                                                  @ignatz
                                                  Hopper,
                                                  Gave the chuck and spindle another look.
                                                  Found that there was a tiny bit of lateral play in the spindle (along bed axis) of 0.02mm ( = 0.0008 inch ). Careful tightening of the screw-collar at the gear end of the spindle enabled me to cut that amount in half. The spindle still turns freely.
                                                  The chuck does have some bell-mouthing, oddly enough, only on one jaw. That is showing some daylight and I can just slip a 0.05mm shim ( = 0.00197 inch ) into the split at the very front. This would suggest I should dress the jaws with a grinder held in the toolpost with the chuck jaws tensioned and the lathe turning at low speed.
                                                  I'm going to check up on that bell-mouthing again once I have some ground silver steel bar in hand.
                                                  Am I correct in thinking that I should first address any play in the spindle journals (by lapping the shims) before doing anything to the chuck?
                                                  #364999
                                                  Martin of Wick
                                                    @martinofwick
                                                    Posted by Hopper on 01/08/2018 11:19:40:
                                                    Martin, chuck runout has no bearing on the test piece once a cut has been taken over it. Even if the chuck is off centre and cock-eyed, the turned surface of the test piece will be in line with the lathe spindle. .
                                                    We have already established the lathe is turning tapers, the challenge now is to identify the reason by a staged process of investigation and rectify.
                                                    Agreed, if you only consider radial runout of the chuck. Radial runout doesn't matter that much. However, you also need to consider the axial runout, and 1+ thou runout behind the chuck is small and probably not the main cause of error in this case, but if it was 2 or 3 thou, you might expect 4 to 6 thou angular deviation 100mm out from the point of measurement if that error was consistent through the chuck body (because it might only be the back face of the chuck/backplate that is out).
                                                    Try this experiment, take a small piece of straight thick wire, put a slight bend in it, imagine one side is the work piece in the 'bent chuck' and the other side the spindle, twirl the 'spindle' side between thumb and forefinger as if in the headstock, observe the circle described by the workpiece end and then imagine a tool cutting on an axis parallel to the spindle – result is a taper cut (as you may get with workpiece set poorly in a bellmouthed chuck).
                                                    However, in the two cases of distorted or a bellmouthed chuck, the effect will be the same, i.e., the end of the work piece is most likely to precess as per the bent wire experiment, which would lead to work piece being cut narrower at the tailstock end than at the headstock. From the measurements provided, I think I am right in saying the test piece is actually narrower at headstock end following the cut, by some 3.5thou over 3.5 cm, (sorry to mix systems!) turning a longer piece say 10 cm would mean a taper of approx. 10 thou over the diameter, which may be significant (or not at all, depending upon the intended use of the piece)
                                                    Assuming the work piece is well mounted, there are no bellmouthing issues and Ignatz wishes to remove the sources of error, there aren't too many options left to consider now, most likely being headstock alignment or possibly a twist to the bed or concatenation of both. Easily addressed once you diagnose the problem
                                                    The original question was 'is my 10 a boneyard candidate', the answer is clearly no, it is not. It is just a 50 year old lathe that has recorded all of the bad habits if its previous owners. The simplicity of the 10 is it will only need some minor adjustment once the issues have been fully identified. It will then be capable of sustained and accurate work
                                                    #365003
                                                    Martin of Wick
                                                      @martinofwick
                                                      Posted by Ignatz on 01/08/2018 14:05:00:
                                                      0.4 of a thou axial play is fine, leave the spindle bearings until after you have confirmed spindle/headstock alignment (as you confirm the finish is acceptable for now)
                                                      Bellmouthed chuck unless really severe, or you are mounting the work right at the front of the jaws, is more of an irritation than a real problem.
                                                      Suggest you grind jaws(with jaws griping something inside) only after you are happy with the rest of the system, or simply buy a new chuck keeping the old one for non critical work
