minnie 1″ scaled to 2″
Home › Forums › Beginners questions › minnie 1″ scaled to 2″
Viewing 25 posts - 1 through 25 (of 32 total)
  • #276060
    james huxstep
      @jameshuxstep40895
      hi there
      fairly new to model engineering just bought myself a boxford BUD lathe to replace the chester one i had and i am looking at building the minnie in 2" scale.
      Do i take it that you just double everything up [bar the boiler] from the 1" plans?
      Are there drawings out there somewhere for a minnie 2" boiler?as i gather the 1" version doubled would not be right and or safe?
      Any help on this matter would be greatly welcome
      James
      #8482
      james huxstep
        @jameshuxstep40895
        general questions
        #276102
          Hello James,
          I think Jason can advise on this. A larger Minnie also offers you the chance to add extra detail.
          pgk pgk
            @pgkpgk17461
            As Neil says .. Jason's the guy for that question. I suppose it also depends on whether you're planning on building your own boiler of buying in.. in which case the boiler builder may well have suitable plans they like to follow. As someone struggling to finish his own 1" minnie boiler it's been a heck of a learning curve although I'd fancy considering a crack at making a 2" boiler (for myself) with benefit of this build. Starting with a 2" boiler would have been a really expensive learning curve with some on the bog-ups I managed along the way….
            Other considerations are the rear wheels at 12" won't be machined on your lathe unless you build some riser system and commercial 2" minnie gear set is a breathtaking £540 + vat and post from blackgates – although in the scheme of things that's just a small part of the total cost. (gear making is next on my list of skills to learn)
            #276118
              You can just double everything up if you want to except the boiler but you will end up with quite a chunky looking engine if you do so. A lot of the parts on the Minnie are from 1/16 sheet and flat bar but could infact be made from 3/32" quite happily on the 2" version. Also things like the tender rivits will look a bit heavy if just doubled up, a better option is to stick with 1/16" ones but use twice as many eg don't double the spacing.
              As Neil says there are a lot of extra details that can also be added if you are so inclined, this is one of the nicest looking 2" Minnies about and was well detailed by Kevin it's builder. Note the water pump has been moved from the boiler side to the hornplate which is well worth doing.
              The boiler will benifit from more tubes of less than double the size of the 1", separate supply from the Manifold to the water gauge and pressure gauge and also worth thinking about adding an injector as you reallly need to have the two water feeds on this size engine and the boiler expector is likely to want to see that too.
              Rear wheels can be rolled and welded from a flat strip and then the two legs of the tee welded in so you won't need to swing a 12" wheel.
              J
              #276124
              james huxstep
                @jameshuxstep40895
                Thanks
                It is a very nice looking engine in 2", just feel like a 2" inch would be more useful to use and 'play' with.The only thing that scares me is the boiler. is it worth buying the pre flanged kits?or flange it yourself, or does that leave just more room for error?Can you do this size boiler with blow lamps? or do you need more heat?dont mind spending more money on kit, if its gonna make the boiler build much more smoother.
                thanks
                james
                #276165
                pgk pgk
                  @pgkpgk17461
                  With the advice of more experienced guys on here and cupalloys I bought a 23kw gas torch for my 1" boiler and even with that I struggled at first until the advice finally sunk in about really insulating the copper from heat losses to get it hot enough for soldering. The mass of a 2" boiler in copper would doubtless be more challenging and likely need a more powerful nozzle which then leads to issues like actually getting gloved hands close enough to manipulate the solder rods without toasting yourself. Insulation for heat loss seems to be the key. Specially if following directions and trying to use different temperature solders. The 24% silver was a pig, the 38% not so bad in my hands and the 55% lots easier
                  I didn't find flanging too much of a learning curve compared to the rest of the job and quite satisfying for some reason though preflanged may save a ruined piece of copper and some time making the formers and re-annealing the sheet – depends on the cost penalty,
                  I started out accepting I was likely going to make a mess of my first attempts at boiler bashing/brazing and bought enough copper for 2 boilers – and used most of it and realistically was prepared to consider making a third boiler before accepting defeat (or that boiler making isn't for me). I've also used/wasted a lot of flux and solder along the way.
                  It's worth the experience and fun of having a go albeit with the usual frustrations when trying something new.
                  #276169
                  Durhambuilder
                    @durhambuilder
                    Insulation is definitely key to successful boiler making. I did a 5" loco boiler with a single 25mm dia sievert torch and an insulating chimney liner, see my album for photos.
                    #276188
                    james huxstep
                      @jameshuxstep40895
                      Wow! U really are insulating it!are they special fire bricks?
                      So the general idea that im getting is keeping the copper hot enough, hence the insulation.
                      So would doing the whole thing in a garage as well as insulation help?
                      I take it you re edit the insulation when u need to reach another joint?
                      If i was to buy one torch for model boiler making, what would it be?
                      Cheers
                      James
                      #276230
                      pgk pgk
                        @pgkpgk17461
                        25mm torch is about 8kw. I certainly don't have the skill or experience to use one that small but it would allow better hand access. It takes a while for me to get the whole thing to temp with pretty good insulation and a bigger burner and I still tend to run into flux exhaustion. But guys around here are pretty smart.
                        Vermiculite fire bricks and fire blankets cut and shaped as necessary are your friend. I tried to find his chimney liner on line..nearest i found was pumice based which is probably another form of vermiculite. I asked all the same questions last year at the beginning of my minnie thread **LINK**
                        There's also pics of my assorted hearth build-ups in that thread… and my errors
                        #276245
                        julian atkins
                          @julianatkins58923
                          I was going to post this on pgk pgk's thread but might be more relevant here perhaps as the subject has been brought up by him.
                          He has used completely the wrong fire bricks, using the heavy heat absorbing bricks. I buy what is now the successor to Thermalite blocks from the builders merchants. They are now grey whereas Thermalite was white. I still have quite a few Thermalite blocks.
                          After a heat up on a boiler you can pick up these blocks by hand after a few minutes. They reflect the heat, not absorb it.
                          pgk pgk's thread exemplifies how not to build a silver soldered copper boiler.
                          The 2" scale Minnie boiler is much smaller than most 5"g loco boilers and ought to be a doddle, and no tapered barrel or belpaire firebox. How pgk pgk has made such a mess of of a much smaller boiler continues to be a mystery, and he has ignored all advice provided.
                          I even offered to go to his home in mid wales and help him out, or he could have come here and have the benefit of my indoor workshop etc for silver soldering.
                          Cheers,
                          Julian
                          #276262
                          pgk pgk
                            @pgkpgk17461
                            Julian,
                            I've never shied away from being criticised and yes, I do recall you offering your direct help but the whole point of this was for me to try and do it myself. If you say I'm using the wrong blocks then please provide a tradename because I'm using light, grey thermalte type blocks as the basic surround/wind break and then vermiculite immediately surrounding the boiler itself. If there's anything else specific I'm doing wrong or advice I've ignored then please share for discussion and my education.
                            pgk
                            #276268
                              Yep as someone in the construction trade I can confirm that PGK is using lightweight aerated blocks that go by trade names such as Celcon, Thermalite etc as his outer hearth. Which I seem to remember telling him to use early on in his build so he took that bit of advice. And the inner bricks look to be scamolex or similar compressed vermiculite.
                              #276270
                                On the question of soldering the boiler in a garage or workshop it really depends on how quickly you wish to be overcome by CO2 poisoning. The big burners needed will soon eat up all the oxygen and leave none for you!
                                There is the added problem of propane producing water vapour which will condense on any cold metal surfaces in your workshop and promote rust. And the last photo on this page shows what the build up of heat can do.
                                As for torches, I would say somethiong with a 26 or even 35Kw burner as that 4mm thick copper will take some heating, the Sievert ones are good but pays to shop around. Also worth reading the "best practice" on that site.
                                #276337
                                james huxstep
                                  @jameshuxstep40895
                                  So if i was going to make a bullet point guide to sucessfull boiler making it would start somthing like this
                                  1/always clean (acid and water solution) before every ‘cook up’
                                  2/insulate the work (with the appropiate brick)
                                  3/dim lights a bit, to make the dull red colour more visible
                                  4/plenty of flux
                                  5/plenty of heat(possibly standard blow lamp close for holding ambient temperature, plus the higher wattage torch for the specific part of job
                                  Anything else?
                                  #276343
                                  pgk pgk
                                    @pgkpgk17461
                                    Since I'm obviously doing it all wrong you should ignore all my 'advice'. One of many things you will find is tthat these burners use up so much O2 that getting it close to the work doesn't leave enough access for fresh air and it flames out. I keep an ordinary small torch lit on the bench for a relight if necessary. I'd guess that a smaller torch aimed at the work with intent to keep some heat in will likely just be extinguished by the larger torch using all air
                                    I do my soldering outside the shed door.. at night, with shed floodlight illuminating. Equally if you plan on dropping hot stuff into an acid bath then it's better done outside standing upwind unless you plan on holding your breath and escaping the shed pronto while everything in there dissolves. you also have the problem of handling annealed soft copper that's still hot.
                                    #276348
                                      Not much point in using a small blowlamp for general heating, you would have more success using the big burner to bring the whole thing upto temp and then using a mapp or similar blowlamp to chase round the joints as the solder flows but as PGK says you will have a job getting close enough with a blowlamp once the main torch is roaring away.
                                      If you can find a friend then have them use the big torch and run a second propane torch with a cyclone burner which is longer as draws its air further from the work so won't put itself out. Use this cyclone one to chase the bead of liquid solder along the joint.
                                      Do it outside, not in bright sunlight or under a lean to roof if likely to rain
                                      #276406
                                        Julian,
                                        Please try and mind your manners.
                                        Thank you.
                                        pgk pgk
                                          @pgkpgk17461
                                          Posted by Neil Wyatt on 07/01/2017 21:39:19:
                                          Julian,
                                          Thank you.
                                          Neil, That's unnecessary. I don't have a problem with Julian voicing an opinion (and I'd hate him to think I'd made any complaint) I appreciate all the help on this site and when I stuff-up I'm happy to be advised accordingly..preferably with explanations of what and why.
                                          pgk
                                          #276419
                                          julian atkins
                                            @julianatkins58923
                                            Jason is quite correct in that pgk pgk is using the Celcon blocks that I use (the big grey blocks on the outside of his pic of pgk pgk's set up), but pgk pgk has used heat absorbing quite heavy vermiculite blocks around the boiler.
                                            The celcon blocks cost a quid a piece and are also easy to cut up with an old wood saw to exact sizes to fit into the firebox etc . Had pgk pgk used just Celcon only he might have got better results. I have always silver soldered my boilers indoors with the workshop door open. A curtain covers the doors and workshop window if the sun comes out.
                                            Celcon is not quite as good as the thermalite white blocks, but the best available atm.
                                            Hi James, I think you have it pretty much correct except as Jason says the secondary heat. I scrub the assemblies in hot soapy water after pickling – it is amazing how much more dirt comes off on this stage. To remove hard deposits of flux I use a different method.
                                            Cheers,
                                            Julian
                                            #276425
                                            Roderick Jenkins
                                              @roderickjenkins93242
                                              Posted by julian atkins on 07/01/2017 23:23:35:
                                              Hmm…..
                                              Looks like I've made the same mistake – astonishing that my boiler brazing seems to be going OK wink
                                              Cheers,
                                              Rod
                                              #276477
                                              pgk pgk
                                                @pgkpgk17461
                                                I knew julian favoured thermalite type blocks but wasn't aware of the anti-using firebricks inside. Indeed as Rod points out they are used /sold as brazing hearths and in the woodburner industry commenst such as needing them to act as liners to prevent the ast or steel becoming too hot.
                                                BUT stirred into thinklng about it.. Yes, they do get hot so they aren't acting that well as insulation and therefore adding to the mass of heatsink one is pouring the therms into. That could have some benefits in terms of storing heat and keeping the item towards temperature but equally the extra time involved has to add to flux exhaustion and leads on to some other thoughts I'd had the other day when working just on one part of my boiler as to whether there may be benefit in heating from the end I had totally enclosed (as in open a window there) so one can raise basic temp of the item without directing the high temp at the flux until necessary….
                                                …I suspect that's what they call experience…
                                                pgk
                                                #276617
                                                Dave Halford
                                                  @davehalford22513
                                                  I began my Minnie boiler in back in the 80's using the book of words. Not wanting to use coke as insulation I thought I'd be clever and get some fire bricks. Being a child of the 50's, fire bricks to me are heavy grey hard things that protect the side of the hearth from too much damaging heat from a coal fire. I can confirm they are medium rubbish at insulation when compared to a bit of Rockwool. They are not made of vermiculite and you can get them to glow eventually, but it takes ages.
                                                  #276627
                                                  pgk pgk
                                                    @pgkpgk17461
                                                    Dave,
                                                    These are vermiculite wood-burner type liner blocks cut from vermiculite board.. not the same as the sort of stuff old pizza ovens are built from that can just cope with the heat cycles without cracking like ordinary house bricks. However I have no doubt that spun as rockwool is way better
                                                    #276675
                                                    julian atkins
                                                      @julianatkins58923
                                                      Hi Rod,
                                                      I think the particular problem here is the wide range of vermiculite blocks available. Some are very light and reflect heat rather than absorb it. I bought a batch off ebay thinking they would be the light type, but they were heavy and absorb heat.
                                                      Cheers,
                                                      Julian
