Typing far too slowly, beaten by the others.
The speed potentiomer is the item driven by the speed control knob. Look for a circular black object about 25mm in diameter and about 12 mm deep, with three wires sticking out of the side. It will be on the other side of the cover from the Speed knob, (which turns the wiper inside the potentiometer. )
If you need to replace it, you need to get one of the same value (in Ohms ) and of the same type, Logarithmic or Linear. Otherwise the speed control will behave quite differently from the original, and obviously solder the wires to same tag positions as before
If you are the slightest unsure about what you are doing, and to what, get someone who knows what they are doing to obtain and fit the new one for you
Howard.
Edited By Howard Lewis on 28/12/2020 17:23:47
