milling on lathe
milling on lathe
Home Forums Beginners questions milling on lathe
  • #6809
    mick70
      @mick70
      mick70
        @mick70
        seen mention of miling using lathe.
        how do you do it, and what tools do you use?
        starting to get hang of using my lathe now and want to try to expand knowledge.
        main thing i would want to do at moment is to put some m10 clearance slots in some 30 x 5 mm flat stock.
        cheers
        #125876
        Bazyle
          @bazyle
          The 'advanced' way is to have a 'vertical slide' (google it) and a collet chuck to hold a milling cutter. However there are lots of simpler methods for simple jobs.
          You can often just hold things in the toolpost if they are convenient small shapes. Working up from that you might be able to take off the top slide and mount the item on the cross slide using the T slots or perhaps fit an angle plate and clamp the job to that.
          You will want to use a slot drill (2 flutes) rather than a milling cutter (4 flutes) for this first job. You can hold a cutter in the 3 or 4 jaw chuck but because they are hard and smooth the grip is poor and it can move. Paper on the jaws might help but if possible make a quick holder from bar with a main hole and a cross hole with a grub screw.
          Edited By Bazyle on 01/08/2013 12:55:56
          #125877
          Keith Long
            @keithlong89920
            As ever the "Workshop Practice Series" has it covered – number 5 "Miling Operations in the Lathe" by Tubal Cain.
            Covers just about everything you need to know when starting out to mill on a lathe.
            Keith
            #125889
            Harold Hall 1
              @haroldhall1
              I have a general article on my website regarding using the lathe for milling and a number of projects for the lathe only workshop.
              For the general article see here **LINK**
              And for the list of projects, here **LINK**
              Harold
              #125962
              Ian S C
                @iansc
                There is an article in MEW no 21, on making a frame to convert the lathe into a horizontal milling machine, there is a two sided, four fold centre page drawing by J. Neave, "A Lathe Milling Attachment", I'm sure I'v got another drawing somewhere of a similar frame, but plus a table that could be made as long(within reason) as you like. Ian S C
                #125993
                Sub Mandrel
                  @submandrel
                  A 10mm cutter will probablty be easily handled by the lathe, but will demand very secure clamping. Any oplay anywhere will result in a slot over 10mm wide, too.
                  I'd suggest using a smaller FC3 cutter (say 6mm) which has the advantage that you can cut one side and then the other to an exact width. I doubt if using the smaller cutter would be significantly slower, either as you can run iot faster and increase the feed rate.
                  Peter G. Shaw
                    @peterg-shaw75338
                    Because my milling machine is out of action, I have been forced to use the lathe and vertical slide for some items.
                    I am no expert on this so what follows is my experience:
                    I use direct collets in the headstock to hold the milling cutter. If you use a chuck the cutter can work its way out of the chuck, and if you use a 3 jaw self-centring chuck the cutter will not be concentric with the lathe centre line. Unless you are very lucky, that is. Another advantage of direct collets is that the overhang from the mandrel is reduced to a minimum which helps to reduce wobble and thus aid cutting accuracy.
                    My vertical slide is 75 or 80mm wide with about the same distance vertical travel. I always use paper between the work and the jaws: this helps to improve grip and thus reduce the risk of the work slipping. If the work is rather large, then I use a pair of plates, one each above and below the work, with the obligatory pieces of paper. The idea here is that this helps to spread the clamping force over more of the work. On my vertical slide, the moving jaw has a pair of 8mm clamping screws to clamp the jaw onto the slide: the procedure here is to setup the work, semi-tighten the jaw onto the work, semi-tighten the clamping screws, tap into pace using a soft(ish) faced mallet, fully tighten the jaw onto the work and then fully tighten the clamping screws. Often, I have to use a piece of tube to undo them, never to tighten them. This is actually self-preservation after having had my knuckles severely rapped by the corners of the jaws when the screws suddenly slacken.
                    You will need to use a dti or similar to line up one of the faces of the work. You may need to use same to align the vertical slide when mounting it.
                    Recently, I was knocking up an adaptor for my lathe which required the removal of an area of steel 22mm x 18mm x 5mm deep. I used an old, broken 12mm Rippa end mill at a speed of 500rpm. It was held in a 12mm direct collet, the work was securely clamped up with bits of paper and it worked very well indeed – much to my surprise.
                    As Bazyle has said, you will need a slot mill for your particular purpose. I have only done a 6mm slot in brass but by using the above principles, it was cut quite easily indeed.
                    Peter G. Shaw
                    #126045
                    Gordon W
                      @gordonw
                      I've only tried very simple jobs, eg milling a small flat. I don't have T slots so drilled and tapped the cross slide. Bought a flycutter to face a big piece, then hit the big problem, not enough travel on the cross slide, should have thought of that first ! I do have an idea for my next job, which is a small keyway. Mount the topslide on a big angle plate and use as a vertical slide, any reason why that will not work ?
                      #126047
                      mick70
                        @mick70
                        thanks for all the advice.
                        have ordered the tubal cain book got a couple of the w/p books.
                        will add bits i need to list of wants for birthday next month.
                        nice site harold spent while goingthrough it.
