Milling Aluminium
Milling Aluminium
Viewing 2 posts - 26 through 27 (of 27 total)
  • #282931
    Dave Halford
      @davehalford22513
      left over engine oil brushed on the cutter stopped ali sticking to my 3" da 3/8 horizontal cutter in my Centec2A-, you really need to brush the swarf away though, makes quite a mess if you don't.
      Same thing worked for the Dovetail cutter except swarf under the cutter is harder to keep away.
      BTW I thought WD40 was mostly paraffin anyway.
      Paul Lousick
        @paullousick59116
        Problem solved. Installed flood coolant system and no more of the aluminium sticking to the cutter.
        Thanks for the advice from everyone.
        Paul
