Paul, I don't know how 'assembly paste' compares with CV joint grease, which is pretty special stuff, compared to 'ordinary' moly grease.
Graphogen is a trade name of the graphite-loaded one I have used. The MoS paste I use is Australian, Molybond GA 50. I think Rocol have a similar product, but haven't noticed it in NZ. The GA 50 blurb states: '…containing 50% molybdenum disulphide powder in a lithium based grease used as an anti-seize and anti-scuffing compound for metal parts. It has an extremely high load-carrying capacity and a wide temperature range of -10C to 150C (suitable for use up to 400C as an anti-seize compound). This product does not contain copper, nickel, aluminium or graphite.' So it sounds like the answer to a maiden's prayer, doesn't it? I think its solids content is much higher than (most?) other moly greases. It really is useful for all sorts of things, particularly highly-loaded sliding surfaces of similar metals.
Incidentally, scroll chucks benefit from intelligent lubrication, not just any old oil or grease. Their clamping force can be dramatically increased by using such a lubricant, or a ferociously expensive one, Kluber Altemp Q-Paste NB 50, as specified by a European chuck manufacturer. I had to lie down for a bit, after buying some, years ago. I don't know if it's still available. Worth it though – it goes a long way.
