McCulloch Strimmer problem
Home Forums Beginners questions McCulloch Strimmer problem
  • #76509
    David Clark 13
      @davidclark13
      Wanted for non internet user.
      He has a McCulloch hedge trimmer and he does not get much spark.
      The coils have been professionally tested and are ok.
      He turns it over with a power drill and does not get a decent spark, sort of a flicker.
      Anyone have any suggestions as what to test next. There is some slight magnetism in the magnets on the flywheel but he does not know how much magnetism is needed.
      regards David
      Edited By David Clark 1 on 19/10/2011 15:18:04
      David Clark 13
        @davidclark13
        Magnets on hedge trimmer
        #76511
        JohnF
          @johnf59703
          Presume he has tried a new or different plug?
          Is it electronic ignition or a magneto? If its a magneto try a new condenser, at one time they either worked OK or were dead but now they don’t die completely and can give the effect you are seeing.
          Good luck John
          #76512
          Gordon W
            @gordonw
            Check the air gap between flywheel mag and coil end, if it’s that sort. Don’t know what the gap should be, but usually works at the minm. gap.
            #76515
            Richard Parsons
              @richardparsons61721
              David
              The McCulloch engines I have fixed have magnetos. They use a form of CDI units this takes the form of a pair of coils wound round a 3 poll pieces or sometimes 4 on older models. The magnets are generally fixed into the fly wheel in the form of a small patck of them.. There are no condensers or contact breakers in the classic sense.
              Test 1 take a ¼” (not a 6mm) screwdriver place it on the magnet and try to lift the magnet. If you can lift the magnet –OK if you can almost lift the magnet Humph try it. If you cannot lift the magnet it is duff.
              Ok you have had the poll pieces and coils tested.
              If the magnet is OK then reassemble the magneto using a piece of normal paper folded in half as the distance piece between the magnet and the poll pieces. Do not connect the ‘stop wire’ at this point. You should now try to get a spark. If you do get sparks at about 400 RPM, reconnect the stop wire and try again to get a spark.
              That is about all.
              Dick
              #76524
              Terry Lane
                @terrylane
                The main problem is it’s a McCulloch – best to throw it as far down the paddock as a double handed throw will allow and get a Stihl.
                #76530
                Sub Mandrel
                  @submandrel
                  In the old days they used to remagnetise magnetos by putting a decent DC current down the coils for a second or so (12V battery). If it still doesn’t work, reverse the polarity (of the neutron flow?)
                  If it still doesn’t work you have proably burned out the coil (don’t blame me…)
                  Jeff Dayman
                    @jeffdayman43397
                    “In the old days they used to remagnetise magnetos by putting a decent DC current down the coils”
                    Neil, I have no doubt that would have worked on some very old magnetos with soft iron bar or horseshoe magnets, but if you do that to any modern small engine magneto coil 1950’s to now you will simply burn it out.
                    The McCulloch and most other small engine magnetos use powder metallurgy permanent magnets embedded in the cast flywheel to generate a primary current in the coil as the magnets pass by the coil’s iron core laminations. The magnets do this by completing and breaking a magnetic field between the core and the magnets, inducing current in the primary coil. Older magnetos use points to trigger a high voltage spark in the secondary winding when the points open and break the primary current flow, with a condensor to limit current at time of the points opening to extend the point life.
                    Newer units have a second, smaller coil, called a trigger coil, which generates a signal voltage to switch an SCR and allow a large capacitor to discharge to the spark plug. The capacitor is charged by the primary voltage.This is CDI ignition. If the trimmer has CDI and there is no spark, there are no serviceable parts and the whole coil assembly is scrapped and replaced. They are usually potted with plastic inside a sealed case and when they go, they are gone.
                    Others have mentioned the flywheel to coil gap, and as suggested it would be worthwhile to try and set the gap with a few sheets of paper (about .006″ is a common coil/flywheel gap spec).
                    Magnet strength is sometimes an issue with small engine flywheel magnets, my own rough test of the strength is that if it will hold up a 3/8″ drive 1/2″ socket stuck to the magnet when lifted up off the bench upside down, it is OK. However on very small engines like chainsaws and maybe this trimmer the magnets are much smaller and their attraction force is correspondingly less. If the flywheel in question will not hold up a 1/4″ drive 1/4″ hex socket it may have lost its magnetism, in which case a new flywheel is needed. They can not be re-magnetised, in my experience. I was told they are magnetized at the manufacturers’ by holding them in an extremely powerful magnetic field generated by high currents in an induction coil.
                    If the gap check and magnet check result in no spark, and the trimmer is CDI ignition, then the coil/CDI assy needs changing out.
                    Good luck to OP with the trimmer. Are there any McCulloch dealers left in UK? None here in North America that I know of for parts anymore, but tyhere could be someone with a stash of NOS. You might check Smokstak.com’s small engine forum.
                    JD
                    PS- TEL – the Stihl’s are OK if you like boat anchors, but give me a Canadian made Pioneer saw or US made Remington saw from the 1960’s – 1970’s and I’ll never get tired out – they’re that much lighter, and have bigger engine power per CC than new ones of any make. Not many parts for them around anymore either though.
                    Edited By Jeff Dayman on 20/10/2011 01:52:48
                    #76547
                    Terry Lane
                      @terrylane
                      I love my Stihls Jeff, switched over from Husky’s about 30 years ago and stayed with ’em ever since – we currently have seven working saws here and a couple of weedeaters.
                      #76558
                      Ian S C
                        @iansc
                        I’v got a McCullock chainsaw motor on the bench at the moment, I would like to know what sort of revs it does, its going to power a bike.
                        Before I overhauled it I looked up Mccullock overhaul on the net, and the method used is the rubbish wheelie bin, But it goes, so it stays.
                        I’v got access to a remagnetiser, and its been used on the mags for old hit and miss motors etc. Ian S C
                        #76559
                        KWIL
                          @kwil
                          My small McCulloch chainsaw uses a 30cc engine, about the same size as the strimmer. The magnet just tugs at a small 1/8″ screwdriver when apprached from the back (ie through) the flywheel and it starts very easily on what appears to be a small spark. The settings of the needle jets are quite touchy, but once set are fine. It is a bit sensitive to over oiling the fuel.
                          I believe the old McCulloch company is dead and a new McCulloch seems to have appeared from the east.
                          #76581
                          Keith Wardill 1
                            @keithwardill1
                            I had a similar problem with a strimmer, and got all this advice through this forum – in the end it turned out that the flywheel/magnet assembly had turned slightly on the crankshaft, so the timing was incorrect (I was assured this was absolutely impossible, since the wheel was keyed to the shaft – wrong – not sign of any key at all, simply a tight (?) friction fit). I can’t account for the weak spark, mine was the same, but KWIL si probably right- there was only a very weak spark anyway – anyway, it ran fine once the timing was reset.
                            #76610
                            Sub Mandrel
                              @submandrel
                              Hi Jeff,
                              I accept my advice being out of date – I now that’s how people ‘restore’ Fordson Tractor magnetos, although the owners manual advises buyiong new magnets (MRDA).
                              Ian S C
                                @iansc
                                With the older magnetos with iron magnets or ALNICO, it was important to not break the magnetic circiut, or the strength was soon lost, no problems like that with modern ceramic magnets.
                                My McCormick- Deering magneto servicing book even discribes a remagnetizer and its use. If your mag is the old points style check the condenser. Ian S C
