A strong solution of Copper Sulphate with a dash of Sulphuric Acid.
I wouldn't bother. The only advantage is that very fine lines can be ruled on it. The copper film is supposed resist wear and tear but my experience was disappointing.
Everything else about Copper Sulphate is a faff. You have to make up the solution and avoid spilling or drinking it. Don't get it in a cut. Only works on clean steel, not stainless, and has to be applied liberally and left until the copper film forms. Has to be dried before use. The resulting film isn't all that clear and the lines can be hard to see.
All the alternatives are better. Try a good felt-tip marker (not pound shop cheapies) – they work nearly as well as proper marking fluid.
