I have been tasked by SHMBO to restore a brass bed which she picked up for nothing.
The bed is screwed together with unusual threads ie: 1/4" X 22TPI thread(5/16" X 22 TPI being BSF) both left hand and right hand.
I have some of the screws and nuts missing and have made some studding by screw cutting the nuts I need to tap.
I have searched the internet for non standard threads and even Tracy tools don't keep this size in right hand nor left hand and the price is prohibitive to have some specially made.
So I have thought about making taps and then making a die.
When I have usually made taps and dies I have used silver steel and gauge plate.
What material do other model engineers make there taps and dies out of.
I have made taps at work out of HSS but don't have the heat treatment plant that I once had available, So do I use another material which I can harden but also have a good tough core strength which is hard to achieve with the standard silver steel.
I could case harden and this would probably do the job after I have cut the flutes in the tap.
