Hi Brian
To save remachining the tool bores you may find that using steel shim to bring the turret tooling to centre height is an option, when you arrive at the exact thickness required use Loctite or similar to permanently secure the shimstock to the underside of the turret. It is important for drills, taps and reamers to be on centre height, some other tooling may be used off centre.
From memory the tool holes are 5/8" and when I used the same device for small drills, taps and reamers I would drill/ream a suitable size hole into a blank toolholder and the securing screw would bear on a flat machined into the blank before loading, this ensured accuracy of the tool when refitted to the turret again, for the most used tools these would be loctited into the dedicated holders.
Emgee
