Making M Type Drummond lathe cross slide leadscrew nut.
Home Forums Manual machine tools Making M Type Drummond lathe cross slide leadscrew nut.
  • #465527
    David George 1
      @davidgeorge1
      With the lockdown I thought that I would make a couple of spare nuts for repairing worn threads in crosslide casting. The thread us cut straight into the casting so when wear becomes to much the only option is to bore out and replace with a phos bronze bush.
      Screw cut and tap and check with leadscrew.
      David
      David George 1
        @davidgeorge1
        #465535
        old mart
          @oldmart
          Is that a RH square thread?
          #465546
          David George 1
            @davidgeorge1
            Yes Old Mart it's a 1/2 inch OD 10 TPI RH square thread.
            David
            Edited By David George 1 on 18/04/2020 19:08:31
            #465551
            old mart
              @oldmart
              I would have expected a left hand thread with a cross slide. Is the nut attached to the saddle?
              Edited By old mart on 18/04/2020 19:29:30
              #465553
              geoff walker 1
                @geoffwalker1
                Good idea David.
                something I need to do but never get round to it.
                When you say screw cut AND tap what do you mean?
                Geoff
                #465555
                not done it yet
                  @notdoneityet
                  • I would have thought that brass or even (ordinary) bronze, would impart less wear on the lead screw. Very few would consider making a lead screw nut in phosphor bronze.
                  #465569
                  David George 1
                    @davidgeorge1
                    I made a finnish tap from silver steel hardened and tempered just t make sure i can repeat sizes.
                    David
                    #465701
                    geoff walker 1
                      @geoffwalker1
                      Hi David
                      OK, I'm with you now and I can also now see the tap in the first photo.
                      So presumably you machine the thread almost to size and skim out a small amount with the tap, good idea.
                      Have you already fitted a nut to your M?
                      If so I would be interested to know how you held the saddle then bored out to size for the nut.
                      Geoff
                      #465703
                      geoff walker 1
                        @geoffwalker1
                        David
                        Just had a look at your photo album.
                        Nice work
                        Geoff
                        #465711
                        David George 1
                          @davidgeorge1
                          To fitt the new nut. The saddle was stripped and removed and set up in the mill against an angle plate, picked up the centre and bored through. The head recess was machined at the same time and the screw holes for the retaining screws. The bush was locktited in and screws fitted, job done.
                          David
                          #465738
                          geoff walker 1
                            @geoffwalker1
                            Thanks David
                            I've sent you an email.
                            Geoff
