Posted by Neil Wyatt on 22/02/2018 21:57:57:
Posted by vintagengineer on 22/02/2018 21:30:54:
Copper melting point 1085C Tin 232C. Won't have much tin left!
Copper starts dissolving rapidly in tin at about 450C, a darn site easier to do than melt copper.
How do you think people did it in the bronze age?
Brass is, I think, much harder to make than Bronze.
Originally it was made by mixing 3-parts of Copper granules 'beanshot', to 1-part of calcined calamine (Zinc Carbonate) in a crucible and exposing them to 'bright ignition'. The process was hit and miss and highly skilled; the worker was dealing with impure ingredients. Much depended on the local ore.
In 1791 James Emerson patented a process for making brass directly from Zinc(1 part) and Copper (2-parts). His 8 to 10 hour process involved plunging slips of copper into molten zinc, and then raising the heat to dissolve the rest of the copper. After cooling the first melt is broken into pieces, mixed with more Zinc and thoroughly stirred before being cast into an ingot in a graphite or granite mould. (Graphite preferred.) The second melt is important; it much improves the quality of the alloy!
Later the Victorians improved brass by first melting the copper, cautiously adding the zinc, and then stirring. This avoids the need for a second melt plus it's easier to control the exact mix to produce different types of brass. I believe most modern alloying is done by starting with the metal having the highest melting point and working down to the lowest, adjusting temperature as necessary throughout. The reason is unclear. As it's harder to melt metals that way it must be important. I think it's because the metals mix better that way round.
Digging into this revealed blurred ideas in the past about Brass and Bronze. Ancient 'brass' is bronze. An alloy of Iron, copper and calamine, – a form of gun-metal – was once called brass. On the continent brass usually meant bronze. It's also possible to have a brass with tin it and a bronze with zinc in it. These days it's 'Brass' if it's Copper and mostly Zinc, and 'Bronze' if it's Copper and mostly Tin. There are multiple different brasses and bronzes.
The meaning of 'gun-metal' seems similarly blurred. The colour 'gun-metal' is a steel-blue, whereas 'gun-metal' is a copper alloy. I think it's because 'gun-metal' originally meant the metal from which guns are made, rather than a particular material. So depending on the period and country 'gun-metal' might refer to Brass, Bronze, Cast-Iron, or Steel.
Zinc is volatile and the fumes are dangerous. Modern Brass may contain small quantities of lead and cadmium, which are also toxic. Ditto Bronze which might also contain Phosphorous. Like cannabis, it's best not to inhale…
