Machining copper
Machining copper
  • #446325
    Trevor Roberts
      @trevorroberts83547
      HI
      Can anyone advise on machining copper. I am working on a boiler and I have trim some plates in the lathe, would I use the same shape of tool as for machining brass?
      I also have to drill a large number of holes, what would be the best drill bit shape. Should I modify the drill bits as if I was drilling brass?
      I obviously don't want to 'tear' or otherwise damage my prepared copper plates/barrel.
      Thanks in advance.
      Trefor
      Trevor Roberts
        @trevorroberts83547
        #446336
          A tool with more top rake will work better like you would use on aluminium or a **GT insert if you prefer inserts.
          For larger holes to take bosses and firetubes I would go with a step drill and have never bothered to alter smaller twist drills for brass, bronze or copper.
          Full fat milk makes a good cutting fluid.
          #446344
          nigel jones 5
            @nigeljones5
            As a full time copper boiler maker I do quite a bit of this…..I only ever use CCGT tips (as per JB) for turning copper as they out perform everything else by a country mile – no grabbing and clean cuts. Standard drills are fine but beware that your holes will all come out slightly under size. You need to lubricate when drilling copper, and it gives a better cut when turning, I use wd40 as it does the whole machind good and doesnt smell bad. Good luck!
            #446349
            Martin Kyte
              @martinkyte99762
              Lots of rake. Definitely not zero or negative rake as for Brass.
              Drilling holes, twist drills ground to a brad point wood bit form work well. The sort with a central triangular bit in the middle and the corners proud so they start cutting before the flanks. This gives a clean hole with no burr on the reverse side.
              regards Martin
              #446351
              old mart
                @oldmart
                It's always a good idea to try the recommended tooling on any offcuts of the metal first to get a feel for yourself. That way there will be no danger of spoiling the actual workpiece.
                #446375
                Trevor Roberts
                  @trevorroberts83547
                  Thanks everybody for your replies. I'm going down to the workshop now to do some tests/practice on some scrap copper.
                  Thanks again
                  Trefor
