Had an industrial placement at English Electric Valve Co's Lincoln factory around 1984, working on microwave duplexer production and test. These were for pulsed radar with peak power in the 10s of kW – but average power much less than that. If I switched on the duplexer leakage tester I was developing without remembering to insert a duplexer, you could smell the ozone. Radar / microwave doesn't do anything insidious like sterilise you or give you the Big C on the sly – if anything you'd wonder why your skin was getting hot. I never noticed anything beyond the ozone smell.
It could have been a factory making plumbing fittings, as most of the materials were copper, brass, ceramics etc and processes were induction brazing, spot welding etc. The biggest valves they made then were giant thyratrons the size of hot water cylinders. IIRC, they also made parts that went into the Exocet missiles the Frogs had sold to the Argies.
A couple of years before this when I was at school, the Falklands War was going on and a friend and I constructed a 1kW linear amp for 2m band using a couple of valves rather like the finned one shown above. Power was 1kV and they lit up when you transmitted. Despite coupling this up to a large Yagi beam on a rotator, we failed in our quest to contact a family friend on a RN ship down there. Would have been something to talk about but it came to nowt. Quite possibly we would have miscalculated the transmission time but the distance was perhaps a bit ambitious.
Another valve we played with was one of those "acorn" valves. These were tiny by valve standards but we failed to prevent it from hooting uncontrollably at something like 500MHz. Transistors were a lot simpler to use!
Murray
