Hello –
I am looking for someone who could make some small items in brass and steel for me.
The first brass item is essentially a semi-circular arc (the size is approx. o.d.= 126mm, i.d.= 112mm, thickness = 8mm) to be cut, tapped and drilled in certain places.
The second brass item is a simple rod (say 5mm diameter and 40mm long), slightly flattened in the middle with a small hole drilled along the diameter at the centre.
The steel item is a rod about 6mm in diameter and 100mm long, tapered to a point at both ends.
This mysterious list of items are the parts necessary to repair an old demonstration gyroscope.
If you can help then – rather than add to this thread – would you please send me a message to my inbox. I can then supply further details and would be pleased to get a quote for time and materials.
(The gyroscope and I are in Rickmansworth, Herts.)
With thanks,
Alan.
