Looking for someone to create 3D files for a project (and poss print)
Home › Forums › Help and Assistance! (Offered or Wanted) › Looking for someone to create 3D files for a project (and poss print)
  • #652396
    Ian P
      @ianp
      Title says it all really. I have tried Fusion and Freecad but the steep learning curve (and senility!) have defeated me.
      I am involved in an interesting project that I would describe as commercial, its low budget but beer tokens.
      The printed parts are to create the augers for a remotely controlled screw driven vehicle. Several identical components would make up one assembly about 140mm dia and 400mm long.
      Last thought. I know there are 3D print houses but presumably they do not do design, hence asking here.
      Ian P
      Ian P
      #34245
      Ian P
        @ianp
        From sketches and 2D CAD drawings.
        #652401
        lee webster
          @leewebster72680
          Oddly enough I was recently thinking that those of us with 3D printers could offer to do this for those who don't own one.
          If you could post a sketch with dimensions I would be interested in seeing it. Are you thinking of using the 3D printed parts themselves, or casting them in metal? Most 3D print materials are fairly weak, unless you go for exotic materials which come with their own problems.
          I like a challenge. More details please!
          #652405
            A sketch would help enormously. Something like the Screw-propelled vehicles described on wikipedia? The animation is theirs:
            Ian P
              @ianp
              Dave's nailed it!
              The 'parts' forming the would be two bullet shaped ends with several thin wall cylindrical rings between them, all stacked together.
              PM sent to Lee
              Ian P
              #652450
              DC31k
                @dc31k
                Posted by SillyOldDuffer on 15/07/2023 17:45:41:
                Reading the page to which you refer, it says that the helices on either side need to be opposite hand and that the screws should counter-rotate.
                I am not sure the animation reflects this – to my eyes both are going in the same direction and the same hand.
                #652452
                  This one has it right
                  There are also a couple of sites with ready modelled ones that you can download STL files and presumably scale to suit, whole vehicle in some cases.
                  #652464
                  Grindstone Cowboy
                    @grindstonecowboy
                    Posted by DC31k on 16/07/2023 07:19:12:
                    Must be the NASCAR version, for racing on left-hand oval tracks devil
                    Rob
                    #652476
                    DC31k
                      @dc31k
                      Posted by Grindstone Cowboy on 16/07/2023 09:50:42:
                      ..for racing on left-hand oval tracks
                      I wonder in which direction the animation would go. If sat in the cab, I think it would go roughly north west.
                      I suspect that the helix angle of the screw would influence it but have not quite understood how. If the helix went directly front to back (if it were a bolt, it would be a very coarse thread), I think it would go mostly west, quite fast, but if the thread were very fine, would it go mostly north but very slowly?
                      On the 3D print issue, if the parts are supposed to be modular, you have to think about how to join them together. It would not be possible to have just an 'end cone' and a 'middle cylinder' unless a straight, flat butt joint were used.
                      Possibly, you could have three parts – the cone, the cylinder and a joining piece. The cone and cylinder could have an internal groove and the joining piece a double external projection. The parts would snap together like the toy container from a Kinder egg.
                      The other issue to think about when designing the parts is how to print them. The cylinders should be OK, but the conical ends might need internal support material. Printing the helix tapered ends on the cone would not be too bad, but trying to incorporate them into the cylinder might be challenging.
                      There are rules of thumb concerning overhangs when 3D printing. If the design (as in required geometry) is mindful of those rules, it will make manufacturing considerably easier.
                      #652490
                      noel shelley
                        @noelshelley55608
                        From a practical point of view I would consider a cone at both ends to enable the vehicle to reverse ? Noel.
                        #652499
                          Biggest issue will be getting the spiral to stay on the cylinder, layer orientation will play a big part as will type of resin
                          #652501
                          DC31k
                            @dc31k
                            Posted by JasonB on 16/07/2023 13:06:23:
                            When welded steel augers are made, the flights are cut in the same shape as a washer, with a straight cut from OD to ID and then pulled/bent into shape.
                            It is an interesting problem in geometry going from a helix to a flat piece with the correct dimensions. See:
                            https://www.eng-tips.com/viewthread.cfm?qid=489908
