As an aside, and to illustrate the effects of soil substrates. My last employment was involved in the maintenance of Linear Accelerators. (Radiotherapy treatment machines), at a local Oncology centre. These machines are housed in reinforced concrete bunkers, the walls, floor and roof being an average thickness of 1 m. With 25 mm steel plates in-bedded in the walls at strategic places.
In the walls at right angles to the machine centre line and in the roof were lasers. These lasers had to meet at the ISO centre of the beam, which was also the pivot point for the rotating gantry. While routine morning checks are carried out on these lasers using a specially made in-house checking device there would always be a cry for help to the workshops during the run up to winter and late spring. This did not affect just one particular bunker, as all machines required re-calibrating.
The reason, the water table was not far under the foundations and the whole structures settled during the autumn, (the rainy season) and then moved again as the ground dried out during the spring and summer.
Gray,
