I also have both slide rules and Castle's log tables, neither of which have been used for many a year. But, with a little effort, I CAN still use them and for all sorts of complex calculations involving indices, not that I've ever needed them. However, I would challenge anyone brought up in the calculator/computer age to use them in the event that electronic goodies were not available.
I don't know how true it is, but I've always understood that using the mechanical methods, although not as fast or as accurate as electronic methods, did at least give the user a feel for whether or not the answer was feasible or not. In support of this, I can relate two examples of where electronic devices have been proved to be incorrect due to possibly bad programming by the program writer(s).
The first was a calculation involving, from memory, as attempt to calculate the daily interest on a given sum given the annual rate. Using a particular make of calculator gave a wrong answer depending on the order of the calculation. It turned out that this machine ignored anything beyond the 16th (or maybe the 8th, it's a long time ago) decimal digit, whereas an equivalent Casio always gave the correct answer regardless of the order of calculation.
The second was a demonstration by a colleague who was into mapping underground caves and was using Microsoft Basic to perform the calculations. Again, memory is hazy, but I think he was using horizontal and vertical co-ordinates to determine a particular point, and then as a check, reversing the calculation. He did not end up back where he started. It turned out that he was using the standard single precision values. Double precision, I seem to think cured the problem. Interestingly, my Sinclair Spectrum did not display the same problem yet I seem to think it only used one byte more than Microsoft's single precision.
All that is newer, is not necessarily better.
Peter G. Shaw
