Lathe copy attachment
Home Forums Beginners questions Lathe copy attachment
Viewing 2 posts - 1 through 2 (of 2 total)
  • #266187
    Tony Martins
      @tonymartins59025
      Hello
      I use a Colchester Student 1800 lathe fitted with a Hepworth copy attachment and wish to machine a 4 cyl I/C eng valve cam by copying the profile from an existing single cyl eng, I may or may not have had a eureka moment when I came up with the idea that, would it be possible to motorize the pattern i.e.. the single cyl cam with a stepper motor and synchronize the revolutions of this to the revs of the lathe chuck by using a Hall effect bit of trickery i.e.. counting the head stock gear teeth or should I have gone back to sleep again??
      Your good thoughts re this will be much appreciated
      Tony
      Tony Martins
        @tonymartins59025
        Colchester 1800 Student with a Hepworth copy attachment
