Another "What does the team think" query, or rather queries, as there are two!
I have an old but very good IMO lathe, but the 140mm dia chuck is a 3 jaw self-centering that has seen better days. It is OK and servicable, but the wear means it is not very accurate and stuff rarely runs anything like true. So I was thinking of maybe getting a new chuck. But which chuck?
I have a faceplate come 4 jaw independant chuck of about 200mm dia, so was looking at maybe another 3 jaw chuck. Then I read a couple of articles where the use of a 4 jaw self-centering was considered a better bet than the 3 jaw. Mr ArcEuroTrade's 160mm dia Indian made 4 jaw looked attractive, plus one can get soft jaws for it. But the weight is 9.6kg, which seems a lot. The 3 jaw is 7.7kg by comparison. The lathe is a Weiller 280Z, a German machine from the late 1960's early 70's BTW.
So, Query 1, is a 4 jaw self-centering a better bet than a 3 jaw self-centering, even though it is heavier?
The new chuck would also need a backplate, which would have to be made from a piece of material at least 160mm diameter by 60mm thick. I have looked at available material and I could get a lump of cast iron, or steel in either bright or black.
So, Query 2, which would be the best material, cast iron, bright steel, or black steel?
ChrisH
Edited By ChrisH on 31/07/2012 15:17:16
