Posted by Chuck Taper on 15/12/2022 11:04:02:
Naive question.
If building a "x-inch" model that means the scale of the model is x inch = 1 foot. Is that correct?
Whereas a x inch gauge refers to the spacing between rails. Is that correct?
Is there a (simple) relationship between these two selectors or are they incompatible.
A broad question rather! Admittedly not my area of interest, but I read the articles and am still uncertain. The big picture is an unholy mess, but individual examples make sense when drilled into.
Scale is expressed as a ratio, and one way of doing that is in inches per foot. It's a heritage system, quite handy if working in Imperial aka English Measure, otherwise daft as a box of frogs. Equally common in the day, and almost universal now, is for the scale ratio to be dimensionless. 3:1 or whatever, which works in feet, inches, metres and parsecs. As many models are based on a prototype built in feet and inches, inches per foot is still in currency. Anyone not familiar has to engage brain until the puzzle comes together.
But beware, builders aren't constrained to build exactly to any scale! Instead designs are mostly proportioned that way, but detailed dimensions are often changed to suit the technical needs of the model or the track it runs on.
Gauges are even worse than scales. Gauging means 'sized by comparison', a method popular before weights and measures were standardised. There were once hundreds of gauge systems because every trade, company and region made their own up. Mostly consigned to history, but there are several survivals. One has to sort out Z, N, O, OO, Gauge 1,2,3 etc, plus the bigger than garden gauge sizes supported by clubs. Traction engines and boats are different again. I don't know of a single source that lays out all the possibilities.
Is the model scaled down from a size, or is it sized to run on a particular track gauge? Ship models are usually the first, 'our' sized steam locos are usually the latter – they have to run on a track.
Probably best to ask specifically to find out exactly what the gauge of interest means. My experience is miniscule, but I've dealt with gauges by translating them into standard measure, usually Metric because that suits me, and work to that. If you buy a set of plans for a 5" locomotive, the designer should have sorted out the build dimensions for you. though mistakes and omissions aren't unusual. Converting the same plans to 3½" Gauge isn't quite as easy as applying a scale ratio, doubly so if Imperial is switched to metric as part of the process.
The subject would make a good magazine article. Perhaps it's been done?
