keyway on involute cutter
Home Forums Beginners questions keyway on involute cutter
  • #8190
    Dave Smith the 16th
      @davesmiththe16th
      Dave Smith the 16th
        @davesmiththe16th
        Must be something with me and tools, when I bought my lathe a pair of internal threading tools seemed like a useful addition.
        The tips were brazed directly to the shaft so in theory should thread fairly small internal diameters, when the items arrived they were nothing like the picture, the shaft was bent over 90 degrees and the tips brazed to that. Instead of approx 8 – 10mm your now looking at 20mm +.
        Ordered an involute gear cutter, pictures and specs show a keyway, when the item arrived there is no keyway. argghhhh
        Seller offered half my money back, but now i need to make an arbour without a keyway and make sure the gear cannot slip. How much pressure does an involute cutter take? Is a keyway essential?
        Thanks.
        Edited By Dave Smith the 16th on 29/06/2016 17:07:04
        #244681
        Thor 🇳🇴
          @thor
          Hi Dave,
          I have involute cutters bought from a reputable shop and they have a keyway. I have also made my own gear cutters without keyway. I use both types on an arbor without a key, I feed a bit slow I guess and have never had any cutter slip.
          Thor
          #244685
            I've never bothered to fit a keyway into my gear cutters when I have used them, seem to work fine.
            #244687
            Brian Wood
              @brianwood45127
              Hello Dave,
              You can cut a keyway in an involute cutter with a square diamond file. It is slow work on HSS, the alternative is to spark erode it instead
              Arc Euro sell sets of those files. I have no connection other than being very pleased to resolve just such a problem and open out a small half round keyway on a commercial cutter. Taking very light cuts without a keyway does not actually do the cutter any favours, they are intended to cut to full depth in one pass and will lose their edge if made to work in small bites.
              #244697
              Anonymous
                Posted by Dave Smith the 16th on 29/06/2016 17:03:53:
                Must be something with me and tools………………….
                You probably want to start buying from a proper tool supplier……………wink 2
                All my involute gear cutters have keyways, and I always use keys, even though you might get away without it for larger DP, ie, smaller teeth. But then again I drive my cutters fairly hard on rigid machines. Of course Brian is correct, there is no point in taking multiple cuts with involute cutters, it just wears them out and wastes time.
                #244713
                Dave Smith the 16th
                  @davesmiththe16th
                  Proper supplier, mmm the internal threading tools i bought were from a company mentioned on here quite a bit. not sure if you class them as a proper tool supplier though.
                  Or are they just a UK branch of a Chinese supermarket with ever changing stock that can vary from week to week?
                  I need another trip to ARC or an online order for some digital scales i think Tempted by the glass scale kits though.
                  Thanks.
                  #244755
                  not done it yet
                    @notdoneityet
                    My one inch horizontal milling shaft does not have a key slot. Presumably this was deemed good enough for the full power of 1HP of the original motor.
                    Neither do my 250mm circular saw nor my angle grinder. Agreed, it may depend on the contact area and torque, but I doubt the average hobbyist really needs a key, in most situations, for gear cutting.
                    Select your tools carefully. Most rolson, silverline, black spur (and others) tools are avoided by me, unless they are for a one-off easy duty task. 'Buy cheap, buy twice' is a good maxim to follow.
                    #244777
                    Anonymous
                      Posted by not done it yet on 30/06/2016 09:53:09:
                      It might just be an economy measure to make the arbors cheaper? All my arbors, for both vertical and horizontal mills, have keyways. But the horizontal mill is 5hp with a gear box, so high torque when running a typical involute cutter at around 100rpm.
                      I'd agree wholeheartedly with the maxim about not buying cheap tools; they're a complete waste of money.
                      #244792
                      Brian Wood
                        @brianwood45127
                        I think the biggest risk to tooling caused by operating without a driving keyway and relying on the grip from spacer collars alone is to slender cutters, like slitting saws.
                        If the saw stalls in the cut, but feed continues to be applied, even by hand, the result may well be enough to shatter the cutter from buckling, something it cannot tolerate.
                        #245408
                        Howard Lewis
                          @howardlewis46836
                          Apprentices at R – R were taught NEVER to key a Slitting Saw. I narrowly escaped injury when a fellow Apprentice ignored the advice and the Saw shattered! If it jams, the saw just stops rotating. Have NEVER had a Slitting Saw shatter because of a jam up.
                          I use my Involute Gear Cutters without keys and always cut full depth (d+f) have never had a jam up
                          Better to slip than buy a replacement for a broken cutter.
                          #245418
                          colin hawes
                            @colinhawes85982
                            I don't use keys for any of my 1" and 1.25" bore cutters and I've never had a problem but then I don't expect industrial production rates. However, I could forsee a problem if the cutter was fitted in a dirty state and then tightened itself altering the position when gear cutting. Colin
                            #245523
                            mark costello 1
                              @markcostello1
                              I slot 303 Stainless Steel, .051" wide ( sorry no Metric wink) X .373 deep. Broke many, key way or not.
                              #245682
                              not done it yet
                                @notdoneityet
                                Andrew,
                                It may not be the original arbor, but is likely. Doubt it was a cheap economy measure, if original, as it is a Centec.
