I remember Don Young mentioned something about the Derby 4F & 2P valve gear, but was not sure what it was. I had subscribed to his magazine LLAS for a year or two. This morning I came across LLAS magazine #26, dated Feb 86, mixed in with my ME back issues. In this issue Don was describing the building of the 2P. Here are some extracts –
"Just one point to be mentioned for those who have purchased drawings ahead of Sheet No. 3 appearing in LLAS, in that the slideshaft has been moved from the center line of the slides to the top of them. I put the slideshaft on the center line originally because this was the approximate position full size on all engines fitted with Joy valve gear, plus this helped mask the presence of said Joy valve gear in lieu of the authentic Stephenson gear with rockers, but it meant in practice that the .16 inch dimension of metal to be removed between the slides had to be exceded to achieve working clearance for the vibrating links, and although the end result was perfectly satisfactory, moving the slideshaft upwards to what I would call the "LBSC position" means the drawing dimension can be adhered to, thus saving me a query or two."
Note in the text above "slideshaft" refers only to the .38 x .38 x 2.75 bar which is a component of the "slideshaft assembly". The fulcrum pin location was not altered.
In the same issue referring to the Slide Valve –
"Incidentally, when my 4F pencil drawing was traced back in 1974, a poor 6 became a 0, so what should have read .561 inch became .501 inch, something that was perpetuated initially on the 2P. It was in fact a 2P builder who advised me of my error, I guess that by the number of 4F's already running at the time it was a rather obvious mistake, so I simply corrected the drawings and forgot about it. Unknown to me, however, the designer of the Clayton Steam Waggon that has become very popular through a series in "Model Engineer", used those 4F cylinders and repeated my dimensional error."
I hope I didn't make any transcription errors.
Moderator – could you add these comments in the drawing errors section ?
Bruce
