If it's under warranty, before doing ANYTHING to the unit, contact the seller/maker and start a warranty claim.
If not under warranty, you might try the following before declaring a formal FUBAR or SNAFU.
Unplug the unit from the power supply/mains.
Short the power plug pins with a resistive lead to discharge any power capacitors to reduce electric shock risk. (I use a 100 W incandescent bulb inline with my test leads for this.)
Take off the cover and inspect the PCB for burn marks, brown or black smears, or melted traces. If you find any, the PCB will likely need repair or replacement. Don't handle the PCB or components on it any more than you have to.
Remove each PCB connector one at a time and re-seat them CAREFULLY.
If practical remove the PCB and check the opposite side.
Check all screw/wire connections at terminal blocks and devices.
Remove any wire nut outer covers and check the wire connection inside is secure, then reinstall the insulating cover. Check all grounds. Loosen any ground screws and retighten.
Put everything back together and test it.
This method will work to troubleshoot most electrical devices in the shop and home and have saved many with just a loose connection or two from the scrap heap in my shop . Simple, but it has worked for me. Good luck JD
Edited By Jeff Dayman on 21/03/2015 23:34:15
