Is Iron / Steel endlessly recyclable ?
Home Forums General Questions Is Iron / Steel endlessly recyclable ?
Viewing 25 posts - 1 through 25 (of 25 total)
  • #485783
    Kevin Murrell
      @kevinmurrell62078
      Looking at the swarf on the workshop floor made me think about the above?
      Given it could be melted down, could it be reused? Think more of industrial waster than my pile of chips!
      Would this apply to cast iron, steel, all the usual forms.
      K.
      Kevin Murrell
        @kevinmurrell62078
        #485786
        John Haine
          @johnhaine32865
          Yes of course. Iron is an element, short of a stellar core nothing can change its nature. Whether it is economic to recycle is another question.
          #485791
          Thor 🇳🇴
            @thor
            Hi Kevin,
            As John says, iron can be recycled and used again. The small amount of swarf I produce in my workshop ends up in the skip of a nearby Milling, Turning and Welding shop and is recycled to rebar or nails etc.
            Thor
            #485793
            File Handle
              @filehandle
              Iron is not the top priority for recycling as a common element, but still not a reason for not doing so.
              #485803
              Roderick Jenkins
                @roderickjenkins93242
                Most steel is made by blending a mixture of scrap and iron from a blast furnace. I empty my workshop scrap bin into the metal skip at my local recycling cente.
                Rod
                #485809
                Brian H
                  @brianh50089
                  The club I'm in collects all sorts of scrap metal donated by members including turnings and sell them to a local scrapman. Last year it made around £800 for club funds.
                  #485812
                  William Chitham
                    @williamchitham75949
                    Posted by Roderick Jenkins on 15/07/2020 15:00:48:
                    Rod
                    Does it matter if you mix up ferrous and aluminium?
                    #485820
                    Adrian R2
                      @adrianr2
                      Posted by William Chitham on 15/07/2020 15:24:29:
                      Not if you are just dumping it in a "metal" skip. If you intend to sell it you will get more money for separates.
                      #485824
                      Oven Man
                        @ovenman
                        Rod
                        At work and at the local recycling centre there are separate bins for ferrous and non ferrous scrap. There is a huge different in even the scrap value. You are unlikely to recover the cost of the petrol taking steel to a scrap merchant, but other materials can certainly raise enough money for a good night out. Don't think aluminium is very high but lead and copper certainly are.
                        Peter
                        #485825
                        Harry Wilkes
                          @harrywilkes58467
                          Most steel is made by blending a mixture of scrap and iron from a blast furnace. I empty my workshop scrap bin into the metal skip at my local recycling center.
                          Rod
                          Rod is spot on I worked in a steel works for just over 18 years the scrap which when to the furnaces was loaded by a magnet on a cranes so a lot of the none ferrous material was not 'picked up' however a proportion di find it's way into the melt in the way of old fashioned starters/ dynamos and aluminum trim that may have been attached to say a car part.
                          H
                          #485848
                          JA
                            @ja
                            There is scrap steel and then there is scrap steel.
                            Much scrap steel is rubbish, old cars and such like, and contained metals, such as copper and zinc, that are “poisons”. Then there is good scrap such as ships hulls. Then there is very good valuable steel scrap of known providence. Such scrap usually comes from within steel works or rolling mills etc.
                            When steel is made from blast furnace iron in a converter an awful lot of heat is produced. It is usual to stop the process half way and add scrap steel, good or rubbish, to cool everything down.
                            The really good scrap is kept for making high quality alloy steel in furnaces like an electric arc furnace. The higher the quality of steel, the higher quality of steel scrap required. This is known the rising scrap system.
                            The metal that is really desirable to recycle is copper. I believe the mining of 1950s and 60s rubbish tip for copper is seriously being considered.
                            JA
                            Edited By JA on 15/07/2020 17:55:14
                            #485851
                            ega
                              @ega
                              What about the problem of contamination with cutting oil, etc?
                              #485852
                              duncan webster 1
                                @duncanwebster1
                                I spoke to a metallurgist friend of mine (used to work in a steel works) about recycling iron railings. He reckons the 'unsuitable for making new steel' story is a porky put about by government to cover up incompetence. As long as you can get it molten any non metallic impurities float off with the slag. Things like copper, lead and tin which get mixed in with scrap do cause problems., but there wouldn't be an awful lot of those in pre 1940 railings
                                #485855
                                Bazyle
                                  @bazyle
                                  Genuine old victorian railings would be even more valuable to a blacksmith as wrought iron. Less the cast tops,
                                  #485865
                                    Copper and lead pipe from old plumbing brings in the ££
                                    Plus we have two leisure batteries and two big car batteries waiting for the recycler to reopen. A door knocker offered £12 just for the leisure batteries.
                                    There are companies who offer to take them off your hands for free!
                                    larry phelan 1
                                      @larryphelan1
                                      A recent trip to my local scrap man to sell a few bags of copper scrap pipe and old brass fittings produced enough cash to fill my van with diesel on the way home plus a few bottles of wine !
                                      Fair deal, I thought.smiley
                                      #485904
                                      Howard Lewis
                                        @howardlewis46836
                                        For many years, Wellworthy at Lymington used old railway chairs as the raw material for centrifugally cast cylinder liners. Quite an interesting process to watch!
                                        #485980
                                          Posted by JA on 15/07/2020 17:52:40:
                                          JA
                                          Since Bessemer's time steel-making has shifted to scientific principles, with chemistry to the fore. Steel isn't normally made by melting a pile of mixed scrap in a pot and hoping for the best – it doesn't sell well because it's too unpredictable. Modern steels are made to a specification, and most of it is spot on. Huge quantities – 1869.9 million tons in 2019.
                                          The chemistry of steel and contaminants are well known, as are the techniques needed to remove them. As it takes a few minutes to analyse a melt in progress, steel-makers can make adjustments without fuss. Organic materials and light metals burn off while other metals are captured in slag by adding an appropriate flux. Pretty much any contamination apart from radioactivity can be managed, but separating scrap before bunging it in reduces the cost. As a furnace uses massive amounts of energy, it's not always the best way to remove muck. It pays to separate scrap first, and this is often an elaborate operation. Recovery of rare metals is an important side line.
                                          High specification steels may have to be processed several times. They can be made from scratch, but it's often cheaper to recycle similar steels. For example, using old railway lines of similar specification to make new railway lines saves a lot of bother.
                                          Industry consuming steel by the ton report fewer problems with it than Model Engineers, who seem to have constant bother with our tiny jobs. I suggest it's because Model Engineers are less certain of their materials than the professionals, and might also be burdened by skill gaps and haphazard tooling. I suggest poor results are usually down to using the wrong sort of steel and inexperience machining tricky materials – many steels don't machine well. Though some useful steels are no longer made, there's not much evidence that old steel is higher quality than modern steel, and plenty suggesting the opposite. Lord Nuffield's comments on British Steel makers before WW2 are blunt!
                                          JA
                                            @ja
                                            Posted by SillyOldDuffer on 16/07/2020 10:33:16:
                                            In the 1970s the price of ordinary steel scrap dropped below the cost of producing raw, blast furnace, iron. Quite a number of mini-steel works were set up world wide that used cheap scrap in an electric arc furnace. The resulting steel was rolled to produce concrete re-enforcing bar. One was next to the railway station at Sheerness on the Isle of Sheppey. I suspect it has gone long ago.
                                            JA
                                            #487213
                                            Former Member
                                              @formermember31755
                                              #487214
                                              Circlip
                                                @circlip
                                                If it wasn't, China and India would be in deep ****.
                                                Regards Ian.
                                                #487229
                                                Niels Abildgaard
                                                  @nielsabildgaard33719
                                                  My best source of steel is the local farm machine repairer.He buy black mild steel in plate,bars etc for ca 1,3 £ per kg.Made from recycled scrap.
                                                  I have seen his bandsawblade destroyed by a short piece of 5mm spiral drill.
                                                  Carbide and he was concerned.
                                                  It does not melt in furnace and is small enough to defy separation by density.
                                                  The people at workshop was told to be carefull when throwing away carbide.
                                                  Edited By Niels Abildgaard on 23/07/2020 13:59:24
                                                  #487361
                                                  Guy Lamb
                                                    @guylamb68056
                                                    During WWII the GWR had wide spread 'salvage' drives. Salvage being the collection of materials for recycling and not just metal by the way – paper, rags,oil,grease, bones amongst other commodities were sought. A special request was made for used razor blades to be handed in, thousands were collected and £8 was raised, this was then donated to a comforts fund.
                                                    My point being that razor blade manufacturers would be willing to pay a premium for these old blades as their provenance as scrap would be known and trusted.
                                                    Also in former times some larger engineering companies would collect scrap files for resale back to manufacturers. Both these instances are probably examples by which modern day recycling conscience enterprises could benefit.
                                                    #487364
                                                    Circlip
                                                      @circlip
                                                      Nothing like good ole Blue Gillette's for cutting Balsa, much better than any of the new "Replacements".
                                                      Regards Ian.
