Import STL file to alibre
Home › Forums › CAD – Technical drawing & design › Import STL file to alibre
  • #847061
    David George 1
      @davidgeorge1
      Can I import an Stl file into Alibre Atom 3D as I have had a casting digital scanned and can open it with 3D viewer but would like to use it in Alibre.
      David George
      #847063
        No. You would be better off having the scan saved as a Step file.
        There are a few work arounds if you google but not the best option.
        #847115
        Paul Lousick
          @paullousick59116
          There are free Stl to STEP converters online. (use a reputable one and I always scan any files that are downloaded for viruses)
          #847158
          David Jupp
            @davidjupp51506
            There is a good (free) STL to STEP conversion utility available via the Alibre user forum.  It was produced by a UK user, and is available as an ‘Add-on’ which will work in Atom3D in addition to higher levels of the software.
            https://www.alibre.com/forum/index.php?resources/add-on-that-allows-conversion-stl-stp-and-import-of-stp-into-alibre.140/
            You’ll likely find any resulting STEP file of limited use though.  One big challenge from scans is getting a resulting mesh which is watertight, and hence valid in a solid modelling system.
