Imperial pitches on metric Myford 254
Home › Forums › Manual machine tools › Imperial pitches on metric Myford 254
  • #402465
    lfoggy
      @lfoggy
      I want to cut some inch pitches on my metric Myford 254Plus. The manual contains a description of how this can be achieved. You need a gear train with a 48, 60, 63 and 64 tooth gear for all imperial pitches and then 24, 27, 33, 36, 39, 42, and 57 on the input shaft to get the full range of pitches from 4 to 56 tpi.. These are all unusual gear sizes (apart from the 60 which I have) and I am having trouble sourcing them. When I purchased my lathe in 1997 they were offered as an option by Myford but foolishly I did not buy them at the time. I've worked out that substituting a 127 gear  for the 60 gear on the input shaft will enable some inch pitches to be cut  by selecting differnt gearbox settings – that may be my only option.
      Any idea where I can get these gears or any other options?
      Edited By lfoggy on 27/03/2019 23:28:30
      #13471
      lfoggy
        @lfoggy
        #402474
          Myford list the 24, 27, 36, 39, 57, 63 and 64 for an easy start.
          42T on Home and Workshop
          Maybe some here
          If all else fails Boston Gear do change gears of correct DP and pa, should be able to get those via one of their distributors.
          Page 28 of catalogue
          Edited By JasonB on 28/03/2019 07:38:42
          #402475
          lfoggy
            @lfoggy
            Myford do list some of these gears on their website but when you try and order them you find many are not actually available…..
            #402476
              I thought they tended to take them off the list when OS, certainly let me go through to checkout before I bailed out.
              Certainly worth ordering what they have and then search out the rest. They do get new stocks in from time to time though may well be steel gears now rather than cast.
              May be more on Home & Workshop as I only looked for the ones not listed on Myford.
              Edited By JasonB on 28/03/2019 07:55:05
              #402535
              Bazyle
                @bazyle
                There might be a simpler alternative with more conventional gear values. If you can get one set up that gives you an imperial thread, preferably multiple of 8tpi, and only using two gears and some idlers. Then you can modify it with a standard set of gears in steps of 5. You would end up with an extra stage or two so probably need an extension to the banjo.
                #402540
                Brian G
                  @briang
                  Before looking for additional gears, try downloading NThreadsP or BoxfthreadP from http://www.lathes.co.uk and putting in the gears you have. Depending on the pitches and accuracy you need, it might be possible with the gears you already have. I spent a while yesterday looking at the ratios for my son's Chester and found that as well as the pitches listed on the machine's table he can cut 14, 26 and 60 tpi within 0.05% using the existing gears (without a 63 or 127 tooth gear) – result!
                  #402586
                  lfoggy
                    @lfoggy
                    Thanks everyone. The link JasonB sent me (thanks) to Triona ltd was helpful. They have almost all the gears I need apart from the elusive 48 tooth that nobody seems to have ! Without that one I can't use the Myford recommended arrangement. As Bazyle says, there must be a simpler aleternative and I am looking at the links sent by Brian G. Will get there in the end.
                    #402588
                      Have you thought of cutting your own 48T
                      Edited By JasonB on 28/03/2019 19:47:05
                      #402590
                        Or what about something like this which is the right p.a. and just modify the hole, cheaper than Myford too.
                        #402604
                        lfoggy
                          @lfoggy
                          Many thanks for this link JasonB. That just might be the solution. Cutting my own 48t gear is also a good idea. Would be an excuse to play with the new Vertex indexing head I recently bought.
                          #402658
                          Howard Lewis
                            @howardlewis46836
                            Go for it!
                            If you have a Vertex HV6 with a 90:1 ratio, for 48 divisions, you use the the 16 hole circle on the A plate.
                            Index 1 turn and 14 holes on the 16 hole circle, for each division.
                            Howard.
