HQS. What is it?
HQS. What is it?
Home › Forums › General Questions › HQS. What is it?
  • #136659
    Mark P.
      @markp
      I have aquired some M6 taps from the Tap and Die Co. They are marked up HQS, I assume that it refers to the steel they are made from but what is it? To be honest they look quite poor quality, they were bought to replace a set of M6 Sherwood taps which got lost when I moved house.Does the team think that I will get the same amount of use from them (I had the Sherwoods for over 15 years) they were used very frequently in steel/stainless steel ally etc.
      Mark P.
      #22981
      Mark P.
        @markp
        #136665
        Mike Poole
          @mikepoole82104
          I think they are a high carbon steel, a quick touch on the grinder to perform a spark test should give an indication of what the material is. The non business end of a tap will do if losing the centre is not a problem.
          #136673
          Mark P.
            @markp
            Thanks for the reply, thought as much as I said they look "cheap"
            Regards Mark P.
            #136675
            Raymond Griffin
              @raymondgriffin40985
              Have a look at the Tap and Die company website. They refer to HQS as Highest Quality Steel, considered a tougher and better alternative to HSS: cut even stainless steel. I’ve had some taps from them in the past and was happy with them. They are not certainly cheap: take look at the prices.
              Ray G
              #136682
              Sub Mandrel
                @submandrel
                As Ray says, I have heard of HQSS taps as a step up from HSS.
                John Stevenson 1
                  @johnstevenson1
                  Advertising hype other wise you would be able to find more references for it.
                  Popular sizes are Ok on price but anything special is obscene.
                  1 1/8" Whit, normally £170 08 reduced to £105.51
                  Even J&L can't get anywhere near that and they do HSS not monkey metal.
                  #136691
                  Steve Withnell
                    @stevewithnell34426
                    I can't look at the Tap&Die site, it makes my eyes smart.
                    #136695
                    jim’
                      @jim11037
                      hsco= good
                      hss-e=good
                      hqs=never heard of it outside their site……….
                      #136696
                      Jeff Dayman
                        @jeffdayman43397
                        Maybe it's "Highly Questionable Substances" ?
                        or "Hasty Quick Salesmen"
                        or "Hardware Quackery Supplies"
                        Just sayin…..
                        JD
                        #136715
                        mechman48
                          @mechman48
                          I generally take HQS as Asian speak for ordinary HSS, the next grade up for me would be Cobalt, but never having tried any…?
                          George
