How to use a die?
How to use a die?
Home Forums Beginners questions How to use a die?
Viewing 25 posts - 1 through 25 (of 56 total)
  • #183155
    Tom Davies
      @tomdavies31655
      I'm a total beginner at cutting threads.
      I'm trying to cut an M3 thread of a 3mm stainless steel rod. I cannot get the die to start at all — as I turn it it does not cut any threads.
      I have put a small chamfer on the rod with a file, but that does not seem to help.
      The dies I have are not 'split'.
      Is my material too hard, my die too poor quality, or is there a trick I'm missing?
      Tom Davies
        @tomdavies31655
        #183159
          Most dies have a slight taper to the teeth on one side to lead them onto the rod, this is generally on the side that has the size printed onto it so that is the side that goes against the end of the rod.
          Also on a split die you should place it in the holder with all 3 screws loose, tighten the middle and you should be able to see the split in the die open up. Once it has opened a little just nip the other two screws up and then ready to use. It may need running down the thread again at a tighter setting but best judged against your nut or tapped hole.
          Use a tapping fluid or as a get by some oil.
          J
          #183160
          john kennedy 1
            @johnkennedy1
            If it's a carbon die you can cut a split into it by slowly hacksawing it. You can then do as Jason suggests.
            The ones I sawed had a groove and a dimple either side.
            #183161
              Oops too early in the morning, I missed that it was not split which won't help.
              #183166
              Paul Lousick
                @paullousick59116
                Hi Tom
                S/S is harder to cut than mild steel. Cutters tend to rub the surface and not cut if not sharp enough.. Check that it is 3mm dia and not larger. Try adding a taper to the end of the rod, not just a small chamfer.
                Paul.
                #183168
                FMES
                  @fmes
                  Hello Tom,
                  What you would appear to have is a 'die nut' which is mainly used for cleaning a thread rather than cutting a new one.
                  The correct method is to use a split die. If you look at the die itself it has the size stamped on one face, this face is to be showing when the die is in the holder and identifies the 'cutting side' of the thread.
                  As Jason describes, slacken the two outer screws and fully tighten the center screw to open the die ( a lot of cheap die holders do not have a sufficient point ground on the center screw to open the die so be aware), and then lightly tighten the two outer screws.
                  Apply some cutting compound , Rocol or something similar to the rod to be cut and place the die on the thread with the 'cutting side' in contact with the rod.
                  While trying to keep everything square, rotate the die holder clockwise (RH Thread) for about half a turn and you should feel the die bite into the rod.
                  Back off a quarter of a turn and then advance again half a turn.
                  Repeat foward half, back a quarter until the full thread is formed.
                  Now, the thread may be too tight for a nut to fit on, so you need to slacken the centre screw slightly and re tighten the two outers,and then run the thread cutting process again. repeat this until your nut etc fits properly on the rod.
                  Hope this is of help
                  Lofty
                  #183173
                  OuBallie
                    @ouballie
                    Welcome Tom,
                    I've use die nuts regularly, as not all of mine are split, without any problem.
                    As mentioned start with the side/end of the die that has the most chamfer then apply PRESSURE downwards/sideways, depending how the rod is being held, as you turn.
                    The chamfered end of the rod must enter the die for it to start cutting, otherwise you will spend all day getting nowhere. Experience has taught me that, especially cutting a thread on the lathe with dies in Tailstock holder.
                    NO die, nut or split, will start cutting easily without being forced to do so, but it does take practice, and once the first couple of threads have been cut, let the die pull itself along. I still make mistakes by not providing enough of a chamfer on occasion.
                    Most important, as stated by Lofty, back-off every 1/4 turn so as to break the curl of metal coming off. You may actually hear it click as it comes away.
                    DO keep the die square to the rod. Experience once again.
                    Geoff – Expert I am not even though I sound as if I am one angel
                    #183177
                    Ady1
                      @ady1
                      Tuff stuff stainless, very tuff
                      To drill through a 3-4mm thick digital vernier jaw you need to use a carbide tipped tool, HSS often simply bounces off and overheats
                      Try a bit of 3mm wire/mild steel as a practice piece and it's a doddle, the stainless on the other hand will probbly break a tooth on the die, especially if you're doing it by hand
                      #183182
                      Oompa Lumpa
                        @oompalumpa34302
                        Woa! Who said the man is using die nuts? I have a good few dies that are not split dies..
                        Back to the problem. As has been said, stainless can be challenging, as it is a small diameter wire why not stick it in th drill press or lathe chuck and then use the tail stock or the table of the drill press to hold the die stock square. Using a bit of ingenuity you can then BY HAND turn the wire into the die. You will find you need a good bit of pressure to get the thread started but once started you will be good to go.
                        As was said – bit of a taper is better than just rounding the wire.
                        graham.
                        #183183
                        IanT
                          @iant
                          All of my imperial dies are split but most of my metric ones are not. However, the "unsplit' ones should also be accurately set to final size.
                          One solution for you would be to turn a slow taper on the end of your work piece (suggest equal in length to the depth of the die and use a die holder to get the die as straight as possible (a fairly simple turning operation and something always useful to have in the future). You should then be able to get the die started in the lathe. Once started I sometimes take the work out of the chuck and hold it in a vice (better than over-tightening the chuck jaws to stop the work turning).
                          Once you have the thread you want – then turn/face off the tapered part of the work piece.
                          Alternatively – if you have a screw-cutting lathe – "part" thread the work and finish it with the die. Doing this as a two part operation will help get the thread straight, greatly reduce the work the die has to do and you don't need to worry quite so much about final sizing of the thread using just the lathe (wire gauges etc.)
                          IanT.
                          #183186
                          Ian S C
                            @iansc
                            The unsplit dies may be split using a thin cut off wheel in the Dremmel, a few years back there was an article about one of the ME retailers in UK, and how some imported dies were not split, and they had set up cutting gear to split them.
                            When threading SS, do it to size in one go, so before you start get a bit of mild steel, and cut a thread to size, Use a cutting lubricant, and keep turning. The SS tends to work harden, so doesn't like getting a little finishing cuts.
                            Ian S C
                            #183187
                            KWIL
                              @kwil
                              What grade of stainless??
                              #183191
                              Anonymous
                                I had a set of metric taps and solid dies; they quickly went in the bin, as they were very poor quality. I could make a better tap than the ones in that set. Personally I'd start by buying a decent quality split die.
                                Ease of cutting will also depend upon the type of stainless. The most common are the austenitic 300 series. Within the series 303 and 316 should take a good thread, 304 can have a tendency to tear. I've never had a problem getting a die to cut with just a chamfer, about equal to the thread depth.
                                #183192
                                Ed Duffner
                                  @edduffner79357
                                  I didn't see cutting grease mentioned in the thread so far. Is it not needed for stainless?
                                  Ed.
                                  #183194
                                  Hopper
                                    @hopper
                                    The old dodge is to put a small hacksaw cut on the end of the rod on one side. So it makes a sort of groove or nick in the chamfer you have filed on the rod.
                                    When the teeth of the die meet the edge of the hacksaw cut, said teeth will cut into the metal and hopefully continue to do so.
                                    Plenty of downward pressure on the die is needed as you rotate it.
                                    Another way to do it might be chuck the rod up in the lathe. Put a piece of rubber hose over diestock handle so it does not mar the lath ways or slides etc. Push die and diestock against the rod end using the tailstock. Rotate chuck by hand while keeping steady pressure on the die with the tailstock.
                                    #183197
                                    Muzzer
                                      @muzzer
                                      Ed – that'll be the Rocol that Lofty mentioned.
                                      Rather than merely chamfer the front edge of the bar, if it's proving really uncooperative you could actually turn the bar down to root diameter (try tapping drill diameter – about 2.5mm) with a gentle taper back up to 3mm and start on that. As well as giving you a very gentle lead in, it will ensure that the die is correctly aligned, which is going to be another challenge.
                                      If it won't play ball, put it back in the parts bin and get another length of known parentage. Are you certain it's 3mm diameter and not 1/8"? Being oversize wouldn't help either.
                                      Murray
                                      #183200
                                        It's very possible that the failed attempts at threading have work hardened the end of the stainless rod. Many stainless steels work harden very quickly. I would grind, or file a bit of the end, then grind or file (not turn) the lead on it.
                                        Even with fairly small 3mm you should follow Geoff's advice and push the die positively onto the rod to get it started, not just expect it to screw itself on.
                                        Half-decent unsplit dies should be dead to size and there's no real point in splitting them if you are making ordinary threads. With stainless steel, cutting the thread in more than one pass is just a rapid route to blunting your dies.
                                        If the dies are dull grey they are probably cheap carbon steel and may struggle with stainless. If they are bright and shiny HSS then they should be OK. If you have well finished bright carbon steel dies they may well be good quality. Ultimately, the test of a die is the quality of the thread it produces.
                                        Dienuts for truing up tatty threads are hexagonal (as you might guess from the name).
                                        Michael Topping
                                          @michaeltopping17870
                                          As Lofty said if it is a solid die it is a thread repair die, not intended to cut a complete thread. Sometimes they will, sometimes they won't. Best bet is to get a HSS split die, I would never buy carbon steel taps & dies unless it was for a once only use, I have known the teeth to fall of on the first use on St.steel.
                                          Michael
                                          #183203
                                          Nigel McBurney 1
                                            @nigelmcburney1
                                            Sorry these circular dies which are not split are rubbish,(cheap foreign imports) their only possible use is for cleaning up a burred or damaged thread, dustbins the best place for them. On tough materials like stainless,use a split die opened up with the pointed screw in the die holder,the other two screws should be just finger tight at first,lubricate the die with oil Motor oil is ok for one offs, if used lot then a Rocol or similar threading lubricant should be used.When opened up a good die will cut an oversize thread ,thread to the length required ,then close the die a little and thread the work again,with stainless the die must be cutting and not polishing as it will work harden, adjust the die until the correct size of thread is reached. The difficult part is keeping the die square to the work,it takes practice,get some practice by cutting some threads on some scrap brass and mild steel rod first.
                                            #183210
                                            FMES
                                              @fmes
                                              Posted by Ed Duffner on 14/03/2015 11:24:26:
                                              Ed.
                                              Pretty sure I mentioned the use of a cutting compound.
                                              #183214
                                              Vic
                                                @vic
                                                I've found solid dies work ok but I'd rather cut slightly under size on the first pass. Is it safe to split solid dies with a cutting disc or are they likely to break if opened in the stock a little?
                                                #183215
                                                  I think that there are two types of unsplit die.
                                                  Hexagonal dienuts are meant for cleaning up therads by hand.
                                                  Unsplit round dies are for use in a production environment where faffing around adjusting a worn die or taking multiple passes is just a waste of time. use them till they blunt, then throw away.
                                                  This is why they are cheap, they are mass produced for factory use.
                                                  Quality wise, you can get good un's and bad un's. I've never had a naff thread produced by my good unsplit ones.
                                                  Bob Brown 1
                                                    @bobbrown1
                                                    I have tried the cheap taps and dies and regretted it, they would not cut a clean M6 thread on/in stainless steel 316 once purchase a set of Dormer taps and dies problem solved.
                                                    Bob
                                                    #183219
                                                    Anonymous
                                                      I thought that most commercial, and aerospace, threads are produced by rolling, not cutting. For those threads that are cut there are assorted self-opening dieheads, which would be much quicker than reversing a conventional die. Having said that both my Britan and Pultra have adaptors that use conventional dies. Although they all have three adjusting screws, as per split dies.
