How to sharpen expanding reamer blades & how to adjust them?
Home Forums Beginners questions How to sharpen expanding reamer blades & how to adjust them?
  • #803815
    Grindstone Cowboy
      @grindstonecowboy
      A bit of a theoretical question, really – recently obtained a couple of expanding reamers from a friend which are in a bit of a sorry state. Whilst taking them apart for a good clean, I started wondering if re-sharpening is possible. I’d guess the only proper way would be with a surface grinder and some sort of jig? Which is why it’s theoretical – I don’t have a surface grinder!
      Obviouly you’d lose a bit on the diameter, but would that actually matter? Which leads me to my next question – do you set them up by adjusting, measuring across two opposite blades with a micrometer and re-adjusting until you get the size you want, or is there a better way?
      Thanks,
      Rob
      Neil Lickfold
        @neillickfold44316
        I have sharpened them in the past, I did it between centres on a tool and cutter grinder. Grinding them in place at the highest setting that allowed for the blades to be above the cones for grinding.
        I guess in theory they could be sharpened as a set with a fixture so all are ground as a set, like they do with planer blades.
        #803850
        bernard towers
          @bernardtowers37738
          Never sharpened them before but in use I tend to creep up the dim required mostly using the pin as a guide (Im talking heavy truck king pins) but have also done it with small end bushes on GPO Bantams!!!
          #803857
          noel shelley
            @noelshelley55608
            Like Bernard I usually use above 1″ and go one cut at a time and try with the pin. As for regrinding I would set up on a T&C grinder between centres and do 1 blade at a time. Do all adjustable reamers have the same taper ? Noel.
            #803864
              And like a hand reamer is it only the first part of the blade that has the lead in taper?
              I’m the same and just sneak up on the size until the male part fits in. Don’t use them that often but do have some 8mm PGMS that is a bit tight in the usual H7 reamer cut holes so use the adjustable to ease bearings.
              #803889
              Grindstone Cowboy
                @grindstonecowboy
                All good info, thanks. I hadn’t considered the lead-in taper at all.
                I was imagining a stack of blades, just off vertical by the amount of relief angle required, could all be ground together to ensure they are equal. However, if the non-cutting edge is square with the width, they would be resting on one corner, so some kind of accurately made jig with a very shallow saw-tooth profile/section would be needed to support them fully.
                Both of the reamers I have are around 19mm diameter – one cleaned up nicely but seems blunt, the other is sharp, but has rusty spots due to being stored in its original cardboard box.
                Rob
                #804258
                old mart
                  @oldmart
                  Very difficult seeing that they each run in a groove in the reamer body that tapers towards the front. Add the lead in taper and the fact that the blades are set radial to the axis and have to incorporate relief on the rear edge. It could be done on a cutter grinder in a jig one blade at a time or even as an assembly grinding each blade in turn.There is normally a centre at the front end of the body. which would help.
                  #804292
                  Bo’sun
                    @bosun58570
                    Due to having two tapers and two cutting edges, I would suggest the blades are ground in situ.  Any error(s) grinding the blades individually would inevitably render the reamer unusable.  I’ve only used them twice, and was surprised how well they worked for me.  Or was I just lucky?
                    Considering how accurately they need to be made (and assuming they work OK?), some that you see for sale, are ridiculously inexpensive.
                    #809076
                    Grindstone Cowboy
                      @grindstonecowboy
                      Just to update – thanks to the kindness of Reginald Johnson 1, I now have some excellent new replacement blades. Forum generosity and helpfulness wins again.
                      Rob
