Hi all,
Thanks for all your advice. Well, I think I was making a lot of fuss about nothing in terms of getting the rings over the diameter of the piston. Following Dave (SOD)’s sensible advice, I tried fitting an “out of spec” ring over the machining jig mandrel (which is about +0.002″) and it went on without breaking or distorting. The “frozen” gap was unchanged, even when I tried one where the gap had narrowed to 1/16″ during machining. Thanks anyway for your advice.
Noel, thank for your reassurance over the gap after fitting. (And thanks for grinding those drills at MMEX 2022 – I was the exhibition visitor who thoroughly and cheekily remedied your lack of drills to demonstrate your drill-sharpening machine! They are excellent – which was certainly not true before your efforts, with most of them being sold to me by a well-known outlet with negative clearance so they only rubbed on the back edge).
Bernard:
>> Why wouldnt you make a proper piston ring clamp of the right size, could save on broken rings!!!!
Good point – but please can you be a bit more specific? Looking again for 1.125″ ring compressors has got me nowhere, but I did find this website selling tapered-bore rings which I think would be fairly easy to replicate at home for the required size:
PISTON INSTALLATION TOOL
Was this what you meant, Bernard, or something else? My only reservation is that the rings may tend to catch and try to rotated in their grooves when they start in the tapered bore as the rings are very shallow, but perhaps the tricks with string, cable ties, worm-drive clamps lined with tinplate etc. may be used to “start” the ring in the tapered bore. I’m probably over-thinking this (again) but will have a go, material permitting.
So the only loose ends seem to be:
– how much side clearance in the groove?
– how much bottom clearance in the groove?
– can someone be more specific about the fit of CI piston in CI bore to avoid either leakage or seizing in a steam loco i.e. can you elaborate on “normal running fit” and “a good fit”? 1 thou undersize? 2 thou undersize? Or as close to dead size as will avoid interference? I guess that 1 thou undersize will cope with a piston at 100 deg C in an ambient-temperature cylinder (an extreme case I guess) – I’d be worried about anything closer seizing during startup, but perhaps I’m being paranoid again.
Thanks again for all your patience and answers!
Arthur
