How do you fight workshop/shed condensation
Home Forums General Questions How do you fight workshop/shed condensation
Viewing 14 posts - 26 through 39 (of 39 total)
  • #135382
    wendy jackson
      @wendyjackson
      I have been using dehumidifiers for years. over 20 years ago I worked for a paper storage company and they held masses od docs from insurance companies, banks etc. the holding site was an old corrugated roof warehouse block. there was no heating and just around 10 small dehumidifiers. They worked. I also have used one to keep my motorhome fittings dry and its been preforming that duty for 9 years with no faults. I can,t see how they are expensive to run, they only work when they need to. as to temp never found that to be an issue. After fitting the insulation the workshop never drops that low.
      Ziggar
        @ziggar
        i built my shed 2 years ago now. brand new bought from the local shed and general garden wooden building emporium which has now disappeared..!!
        I insulated with 1 inch thick/thin polystyrene boards. Floor, roof, walls and door. then laid10mm plywood from the local plywood supplier over the top of that. Again, floor, roof, walls and door. my 12X6 shed now measures 5'6" by 11'6" internally.
        in addition to this i use a small cheapo electrical blow heater set to give a low, comfortable heat, and left turned on 24/7. It gets turned up slightly in the colder weather that invades my small area of the world [UK] occasionally, but otherwise is left alone.
        I have absolutely NO condensation at all. At least i have seen NONE at all in the time the shed has been built and inhabited. it contains tools such as a lathe and a miller and associated tools and lots of wooden cabinets to support and store said tools. Again,NO condensation.
        make of this what you will. there are also 3 windows in the shed. Glass. and never a bead of damp on any of them.
        in the past 2 years i have had ZERO – 0% of condensation.
        cost of the heater is minimal due to the thermostatic control.
        Edited By Ziggar on 12/11/2013 22:02:49
        #135389
        Nobby
          @nobby
          I double glaze my windows in my workshop/shed with bubble wrap . I cover my lathe's and mill drill with aircraft wheel cover material my son got me when in the RAF silvered on outside and rubberised on the inside
          walls insulated with waterproof Millboard my Father got me Seem to work ok
          Nobby
          #135396
          Russell Eberhardt
            @russelleberhardt48058
            Posted by Steve Withnell on 12/11/2013 21:09:01:
            One thing that will cause condensation is the sun streaming in on a cold winter's day. Everything warms up, sun goes down, condensation forms.
            Yes, but it forms on the window not on the previously warmed machines. Collect the water as it runs down the window and you have a de-humidifiersmiley
            Russell.
            #135402
            Springbok
              @springbok
              this problem has been running on for a number of years in threads not only in this forum but others.
              as far as I can make out it depends on, type of shed, position, insulation or not, windows I could go on suggest looking up old threads.
              Fizzy changing the subject how is twinkle, I got told at the weekend that I was going to be a Great Grandad when tribe came round
              Bob
              #135407
              Douglas Johnston
                @douglasjohnston98463
                Fitting a blind to workshop windows can get round the problem of the sun heating the air inside and causing condensation on cold surfaces. Since this is mainly a problem early in the morning after a cold night the blinds can be removed when the workshop is occupied. Over the winter I cover my machines with a double layer of bicycle covers from the pound shop and stick one of these small silica gel moisture absorbers under the cover. Every couple of weeks I plug the silica gel units into the mains to reactivate them. I have done this for a number of years and don't suffer from condensation, although the workshop is insulated but not heated.
                Doug
                #135408
                Springbok
                  @springbok
                  Be careful with the dehumidifers, dry air can cause irritation of the nose and throat and mummification of everything else.
                  Hi Terry,
                  As a now retired local councellor there was many people who would have liked to have mummified me.
                  seriously when you say mummification do you mean that it dries out everything oil the lot.
                  Bob
                  #135416
                  Mart150
                    @mart150
                    My solution is a differential temperature measuring between outside in inside. I keep the inside temperature with an electrical heater 3 degrees higher then outside. This works for me allready 20 years at low cost!
                    Mart Hurkmans, Netherlands
                    #135421
                    mechman48
                      @mechman48
                      Hi Ronan
                      My garage conversion is in a previous write up on 'heating the workshop'. In essence studding frames, Celotherm insulation (same as Kingspan) fitted, overlaid walls with OSB sheeting, Celotherm fitted to access door & roll up door, loft space rafters covered in plasterboard, loft insulation on top (space blanket give 6" thickness),so far this year has kept the temp stable at 10*C even with the warm weather we've had, supplemented for winter with 2 small oil filled rads, one either end of garage which were switched on yesterday for the first time for about an hr, brought the temp up to a cosy 14-16*C, then turned thermostats down as it was getting overwarm, so far no need for dehumidifier & no signs of rust.
                      George
                      #135456
                      Norman Lorton
                        @normanlorton75928
                        Dehumidifiers work superbly, providing the workshop is reasonably airtight and not draughty. I have used one for six years in a large workshop (triple garage), with a well insulated ceiling but bare brick walls and solid concrete floor, keeping the RH below 60%. At that humidity there is no rusting whatsoever. As a bonus, you walk into the workshop early morning when it is 5 degC and the fact that it is dry makes it feel much more pleasant. After a few hours with electric heating it is up to 14 deg C and the dehumidifier no longer comes on because the warmed air is drier (relatively). When I leave at the end of the day the dehumidifier works hard on the cooling air to control a potentially increasing RH.
                        Yes, the condensing surface dehumidifier is much less effective at 5degC but at that temperature the air contains a lower mass of water, and the external air leaking in is typically colder, and thus carries less weight of water, even if its outdoors relative humidity is 100%.
                        Silica Gel bags simply would not cope except inside sealed plastic bags – there is far too much water to be removed.
                        My dehumidifier is an EBAC CD35, measures 14"x14"x28", costs around £300 and rated at 350 watts typically runs at a 30-50% duty cycle for me. Working fully I find it removes 80-100 cc of water per hour at 60%RH and 10-14 degC. They need a drain drilled through an external wall, unless you enjoy spending time pouring away a litre or so per day!
                        Norm
                        #135460
                        Russell Eberhardt
                          There seems to be some confusion over what causes condensation. Condensation will form on a machine when the temperature of that machine is below the Dew Point temperature. Heating or cooling the air in a room without a dehumidifier will not change the Dew Point. So you can let the sun shine in, or turn on an electric space heater without risk but also without short term benefit. Machines have a high thermal inertia so they stay at a more or less constant temperature.
                          There are a number of weather forecast sites that give both temperature and humidity forecasts. From those figures it is relatively easy to calculate the minimum temperature of your machine tools to avoid condensation. They can then be heated to a few degrees above that temperature at minimum cost.
                          As an example, the forecast for tonight in Cambridge is a minimum temperature of 5 C with 90% RH. That equates to a Dew Point of 3 C so if your lathe is warmer than that you will not get condensation on it.
                          Russell.
                          #135464
                          Trev T
                            @trevt
                            Norman Lorton 13/11/2013 20:21:13
                            19 forum posts
                            I would fully endorse Norm's approach to this problem. I have a workshop consisting of a sectional concrete garage, 16' x 8', to which I have fitted a 38mm Kingspan roof. It has an un-sealed concrete floor laid on a damp-proof membrane, and the 'eaves' have been sealed. All gaps/leaks/draught holes have been stopped up and the doors have been fitted with sealant strips. In other words, an attempt has been made to keep damp air out! I run a dehumidifier constantly when conditions require it – I monitor humidity from within my dwelling by the use of a little remote sensor which reports back to a 'weather station' (£19, bought from a garden centre). The dehumidifier modulates according to requirements and is very economical to run. It can tend to ice-up when outside temp's drop well below freezing, when the inherent heat-pump effect is inadequate, but I solve that problem by the use of a 700watt fan heater set on 'frost watch'.
                            I used to protect our previous motorhomes and caravans with dehumidifiers in exactly the same manner. This ensured that they kept in perfectly dry condition throughout the winter periods. Caravans cannot be sealed up – they have to be gas-vented in various ways – which means dehumidification yields large quantities of condensate (crystals are useless). I have found that treating the workshop this way yields less condensate with proportional reductions in cost, due largely to being effectively sealed. of course, working in the 'shop involves opening the window a little – after all, we have to breathe in order to enjoy our beloved hobby …
                            Trev T
                            #135465
                            Trev T
                              @trevt
                              Sorry about that! My reference to a previous posting seems to have gone wayward, to say the least!!
                              I'll try and make a better job next time (novice at this game!!)
                              Trev T
                              #135658
                              daveb
                                @daveb17630
                                Bob
                                If you work in dry air for any length of time you may develop a tickle in the throat, soreness and a dry cough, symptoms can persist for a few days. Very unpleasant.
                                I should think it would take a very long time for oil to dry.
                                I haven't seen it yet but if the use of dehumidifiers becomes widespread, it's bound to happen,
                                NEWS HEADLINES – The dessicated remains of a 99 year old pensioner, a keen model engineer who disappeared six months ago were discovered by his wife in the garden shed. Our reporter was told that the police officer responding entered the shed and shouted 'Tutankhamen'. It is understood that he found the deceased leaning against his lathe with his hand still on the cross feed, the valve chest in the chuck was beautifully finished and the deceased covered in bronze dust. The deceased's widow stated 'I thought he had been quiet lately.' The coroner, recording a verdict of misadventure said that it was very sad, only another few years and the model would have been completed.
