Hot rail tracks
Hot rail tracks
Home Forums The Tea Room Hot rail tracks
Viewing 10 posts - 26 through 35 (of 35 total)
  • #359796
    Mark Rand
      @markrand96270
      With the weather we've currently got, they could probably achieve sufficient extra stretch in a length of rail with a couple of crowbar weilding navys. smiley
      Bob Mc
        @bobmc91481
        I've got the same problem with hot lines meself…
        #359963
        vintagengineer
          @vintagengineer
          I thought modern welded tracks where allowed to move in their sabots?
          #359964
          Ady1
            @ady1
            I don't know if our "bullet trains" were affected by the heat
            #359983
            Gas_mantle.
              @gas_mantle
              Posted by vintagengineer on 30/06/2018 00:48:47:
              Continuous welded rail is mounted directly onto the sleeper without the old fashioned 'chair' fitting common in older installations. A small rubber mat under the rail bottom adds a cushioning effect as well as provide electrical insulation to the rails if the concrete sleeper starts to crack exposing strengthening wires.
              Once the rail is clipped down it should be unable to move.
                Thanks to Gas_mantle for exposing another interesting technology.
                I knew that improving the wearing properties of railway line was an early and ongoing application of scientific metallurgy – they are not made of carbon steel. (More likely a manganese steel as these are harder and tougher.)
                Before this thread I thought I understood how continuous welded rail accommodated temperature changes. Wrong again. It never occurred to me that rail could be tensioned to reduce the effect. There are some clever blokes about!
                Gas_mantle.
                  @gas_mantle
                  Most rails are hot rolled steel and for CWR they are typically in 600ft lengths.
                  Manganese is used mainly on pointwork, diamond crossings etc where there will be heavy usage / wear.
                  It's not often realised but in modern installations the rails are fed with a very low voltage but are electrically insulated from each other, the wheels of passing trains short circuit the rail to show the position of trains which can be controlled by a signalman 50 miles away.
                  #359998
                  Phil P
                    @philp
                    Peter
                    Is that done using the "Wheatstone Bridge" principle that we learned about in school all those years ago.
                    Phil
                    #360011
                    Gas_mantle.
                      @gas_mantle
                      The track circuits are actually nothing more than a simple low voltage circuit that trips a relay once short circuited by the wheels of a train, this relay can then be used to energise other circuits that are vital for the working of the signalling system. In old manual signalboxes before the introduction of track circuits the signalmen could look out of the window and see the postion of trains under their control but in modern installations the signalman usually can't see the trains under his control so the track circuits display vital information of the precise location of trains relative to the points and signals.
                      The new signalbox at York is still only partly operational but is planned to control the entire East Coast Main line from Kings Cross to the Scottish border. Didcot signalbox just west of Reading already controls London Paddington to Bristol. The intention is to control the entire UK network from 17 signalboxes over the next decade or 2.
                      When the old joke about leaves on the line crops up every autumn it does make the UK rail system sound a laughing stock but the general public don't realise it is a serious condition that affects the integrity of the signalling system and potentially can be dangerous. Modern rolling stock tends to be fitted with disc brakes so there are no brake shoes cleaning the wheel running surface at every brake application, over time a mulch of squashed leaves builds up on the wheels surface this can then start to insulate wheels so that track circuits no longer operate reliably. It's be no means rare for trains to 'disappear' off the signalmans display which of course can be very serious. Of course a build up of mulch on the wheels does affect braking capability and that in itself is a safety issue but in a lot of cases leaf fall delays are when more stringent signalling rules are invoked because of track circuit unreliability.
                      Incidentally, on track circuited lines (probably 90% of the current network) if a rail breaks provided the break is a clean fully open break the track circuitry is destroyed and the protect signal should revert to danger automatically.
                      To return back to the track, in the 60s / 70s it was decided to install steel sleepers on some none high speed lines, the idea was the were cheap and supposedly maintenance free, however in reality they were more of a nuisance than they were worth. As you can imagine steel sleepers are far more inclined to absorb heat making them a pain in the summer when rail expansion is a problem
                      Edited By Gas_mantle. on 30/06/2018 11:40:08
                      #360028
                      Colin Whittaker
                        @colinwhittaker20544
                        In the days of short rails joined by fish plates it was quite simple to introduce an insulated joint so that track circuits could be separated from each other. A simple low voltage supply and low voltage relay was all you needed albeit with carbon silver contacts to prevent contacts from welding to each other thus ensuring that gravity and a spring could be relied on to open the relay when a train passed or something failed. (Don't get me started on the philosophy of fail safe.)
                        But then the buggers in the M&E department said the S&T department couldn't cut their beautiful continuously welded rails to introduce electrical breaks and the track circuits became medium frequency AC devices that were a little hazy about exactly where they started and finished but essentially did the same job.
                        What really complicates matters is a major junction where all the lines have to be track circuited so that a lost wagon will always register on the track circuit no matter where it stops. When I left the railways 37 years ago it was becoming common on the continent to count the number of axles entering a junction and leaving the junction to ensure there were no nasty surprises for the next train.
                        Just to make life more interesting on electrified lines the running rails are used as an electrical return and so the delicate track circuits have to coexist with 100s of AC amps or 1000s of DC amps. (There may be a missing zero or two in there.)
                        Edited By Colin Whittaker on 30/06/2018 14:06:30
