Holding a clutch cone in a lathe
Home Forums Help and Assistance! (Offered or Wanted) Holding a clutch cone in a lathe
  • #465730
    Philip Hardy
      @philiphardy41757
      Hi guys, need some help with this.
      I have a conical cone that is the inner cone on a cone clutch from a rotivator I am currently restoring. I need to take off circa 5mm from the back edge of the cone to give enough clearance for the cone to move inwards and therefore disengage the clutch.
      I'm really struggling to work out how to hold the cone in a lathe, can anyone help?
      I have a photo to show the cone if it helps
      Philip Hardy
        @philiphardy41757
        #465733
        Howard Lewis
          @howardlewis46836
          Turn up an arbor in the lathe, and without disturbing it,clamp the cone to it so that it can be faced to thin it?
          #465744
          Philip Hardy
            @philiphardy41757
            Thanks Hward I'll take a look at that
            #465795
            Hopper
              @hopper
              Drill and tap some blind holes into the cone and bolt it to a faceplate would be another way.
              Edited By Hopper on 20/04/2020 00:31:37
              Edited By Hopper on 20/04/2020 00:32:04
              #465796
              Paul Lousick
                @paullousick59116
                A photo is worth a thousand words to show the problem
