Hoffman dividing head.
Home › Forums › Manual machine tools › Hoffman dividing head.
  • #294761
    vintagengineer
      @vintagengineer
      Could some one please tell me what Module the gears are on a Hoffman dividing head?
      #12954
      vintagengineer
        @vintagengineer
        #294816
        Bazyle
          @bazyle
          If you look at this recent thread on here you can see who has such a dividing head and perhaps send each one a PM. They might not look at the forum often enough to see this particular thread. If you get a definitive answer remember to post it on here so that future searches can find it.
          I imagine 14 or 16 DP would be about right. You could try a couple of imaginary setups and see if they stretch across the gap without a huge idler. If looking for some lathe changewheels to use the centre hole might be more important as you need to be able to bore out to fit, with or without a sleeve and still have some meat in the centre boss of cast gears.
          #294881
          vintagengineer
            @vintagengineer
            It's made in Germany and defintely a Module gear as my DP gear gauges do not match any of the pitches.
            #294886
            Keith Long
              @keithlong89920
              Well if you've got a gear (presumably you have if you've been trying DP gear gauges on it) then just measure the O.D. in mm and use:-
              O.D.= (no. of teeth +2) x MOD
              as a check:-
              MOD = 25.4/DP
              so a comparison with the nearest DP gauges should give you confirmation.
              #294925
              Tony Pratt 1
                @tonypratt1
                The module is 1.5 on the differential indexing gears, I have just checked mine. You can obviously double check what you have.
                Tony
