I used to be a draughtsman working for the MoD as a ships draughtsman. The section I was working in (Ship Section, responsible for hull and associated systems) had, across a wall, probably 12 to 15 metres of shelf space full of "Design Guidelines". In these guidelines were surprisingly, approved and tested methods of doing just about anything concerned with ship design. The concept, as explained by my boss, was that if you stuck to the guidelines, experimentation was minimised, success was, if not assured at least highly likely. By all means deviate from the guidelines, but be prepared to have your design interrogated at length. As proven new developments came along, the Design Guidelines were updated.
So I would suggest that this leaking seal, is just something that needs a bit of care and attention. Almost certainly it's design and construction complies with the associated specifications, this means that all components also comply with specs/drawings etc. I would even wager that it has an acceptable leak rate. The seal would have been tested on assembly/installation but after some use it's developed a leak. Whereupon the whole world of journo's, uninformed public, etc etc all jump up and down and label the builders, designers, users as incompetent, everybody is an instant expert.
Quite simply there are a lot of people who just do not understand the design process.
Merry Christmas, from this wide brown land
cheers
Bill
