HMS Queen Elizabeth: Leak found on new aircraft carrier
Home Forums The Tea Room HMS Queen Elizabeth: Leak found on new aircraft carrier
Viewing 25 posts - 26 through 50 (of 143 total)
  • #332727
    John MC
      @johnmc39344
      Listened to a radio news report on the prop shaft leak this morning, the shaft is 7metres diameter, is it? Repeated an hour later so must be.
      What sort of seal is it? One of those rubber ones that is lubricated by the water around it? The name of these escapes me at the moment.
      Georgineer
        @georgineer
        Posted by Brian Hutchings on 19/12/2017 10:27:27:
        Ships in Nelsons time had outside toilets, they were called heads.
        They still are, even though they are indoors now.
        My Mum was a tracer in Portsmouth Dockyard before the war. One of her colleagues was working on the designs for a new warship and caused great amusement by lettering BRAINS FROM SEAMEN'S HEADS on her drawing.
        George
        #332733
        Martin Kyte
          @martinkyte99762
          Posted by John MC on 19/12/2017 10:49:22:
          The Props are 7m diameter.
          The above link doesn't give shaft dia but the flanges on the 2 gearboxes shown estimate to maybe 1.8m and the output shaft to maybe 1m. The prop shafts by inference should probably be the same.
          regards Martin
          Edited By Martin Kyte on 19/12/2017 11:06:29
          #332734
            @mike89748
            If you go to the Rolls Royce website, you will find it is the propellers which are 7 metres in diameter, and not the shafts. Yet another example of modern badly-trained journalists who do not check their facts. The editors who trained me must daily turn in their graves!
            #332736
            Sam Longley 1
              @samlongley1
              Let's hope they find it is all down to a fishing pot that has been poorly marked then perhaps the RYA & Cruising Association will get a few hundred more signatures on its petition **LINK**
              Edited By Sam Longley 1 on 19/12/2017 11:19:29
              #332738
                Presumably they spent several hours looking for a rating with a bucket and no-one would volunteer…
                #332739
                FMES
                  @fmes
                  Isn't it amazing that the press manages to declare to the whole world our current defensive weakness.
                  Its not unusual for stern seals to leak during the first few sets of trials, and finding them is what shakedowns are for.
                  The '45's suffered from exactly the same problem, but that dwindled into insignificance with the 'other' problems that arose.
                  This leak on a ship of this size is about as significant as a nick in the wiper blade of a new car.
                  Lofty
                  #332741
                  Brian Wood
                    @brianwood45127
                    Posted by Joules Beech on 19/12/2017 09:26:37:
                    Can't they drill a hole to let the water out !!!
                    Many a true word Joules. I am reminded of a holiday story from my childhood when a rather condescending London visitor hired the local fisherman's rowing boat, having asked if it leaked. He was advised that if it did, he was to " pull out that there bung"
                    The boat was launched in a lively sea on a steeply shelving gravel beach, not the most elegant launch but adequate and it was rowed away out of sight round the nearby headland. About 15 minutes later it was seen coming back, riding very low in the water and in danger of losing cargo like picnic baskets over the side. It was now of course very ungainly and landing in those conditions was demanding of both timing and buoyancy. Our London visitor got it badly wrong, the boat broached and was dumped broadside on onto the beach
                    However, he got a round of applause from the beach population as he surfaced with his pipe clamped firmly in his teeth and miraculously it was still alight!
                    And, yes—he had pulled out the bung!
                    #332742
                    Dave Halford
                      @davehalford22513
                      by Ady1 on 19/12/2017 10:03:03:
                      An old Navy guy would just give it a few taps with a Coventry spanner on the night watch
                      The modern navy guys will probbly spend a couple of million sorting it out
                      Edited By Ady1 on 19/12/2017 10:07:46
                      Sorry Ady, but that's a Birmingham screwdriver.
                      #332743
                        @mike89748
                        Can't match that one, Brian, but a pal was fishing from a boat on Loch Morar, the deepest loch in Scotland. Suddenly his pal exclaimed "Oh, look, there's a Drambuie cork on the floor", and promptly picked it up. My pal only just managed to stop him throwing the cork over the side……..
                        #332744
                        FMES
                          @fmes
                          Posted by Martin Kyte on 19/12/2017 11:05:31:
                          regards Martin
                          The seal is a two stage graphite/ stellite ring composite assembly with and emergency inflatable nitrile tyre.
                          And those are the plummer blocks not the gearboxes.
                          Lofty
                          #332745
                          David Colwill
                            @davidcolwill19261
                            Posted by Georgineer on 19/12/2017 10:57:30:
                            George
                            They are not outside the ship though!
                            #332747
                            Martin Kyte
                              @martinkyte99762
                              "And those are the plummer blocks not the gearboxes."
                              Well that makes sense,they did look a little on the small side. The point I was making really is that it took me about 30secs from a standing start with no knowledge of the boat to figure out the size of the props and the general size of the shafting.
                              Aha some data on the seals too.
                              I am a little disappionted that when a subject comes up it generates more moan than engineering comment on the forum. Nothing wrong with a moan but it's nice to pick up some information along the way.
                              regards Martin
                              #332754
                              Mick Henshall
                                @mickhenshall99321
                                I was a Royal Navy Artificer ,Shipwright, the ship is on Sea Trials to sort any snags out,this is a snag, the press as usual just trying to turn run of the mill event into a major catastrophe its a shame they don't what they are talking about, the lads will sort it out just like we always did,Martin makes a good point
                                Mick
                                #332755
                                Jon Gibbs
                                  @jongibbs59756
                                  Posted by Mike on 19/12/2017 12:01:23:
                                  Reminds me of my Dad who was a country bobby in the early 60's complete with pushbike. One day on his regular beat he came across some blokes with the road up and a gas main in the bottom leaking profusely through a hole. The blokes digging the hole didn't know what to do except wait until the gas board arrived. Dad, who was always eminently practical, took a look at the size of the hole, got out his pen knife and whittled a bung out of a green stick from the nearest hedge and managed to stop the leak until the gas men got there.
                                  #332760
                                  Mick B1
                                    @mickb1
                                    Another couple of rounds of jute packing into the stuffing-box, surely!
                                    #332772
                                    John Reese
                                      @johnreese12848
                                      I share your opinions of modern so-called journalists. They don't know anything. They don't research anything. They sensationalize everything. They ae the same here in the US.
                                      #332775
                                      MW
                                        @mw27036
                                        Posted by John Reese on 19/12/2017 15:56:58:
                                        Exactly, these problems happen all the time, yet because this is the big cheese at the moment, they've gone over with a fine tooth comb to look at any flaws.
                                        Do you think they would've bothered reporting a leak on a ship in WW2 when plenty are being blown to smitherines, I wonder.
                                        Edited By Michael-w on 19/12/2017 16:25:07
                                        #332777
                                          Posted by David Colwill on 19/12/2017 12:07:03:
                                          George
                                          Jon Pertwee was yarning on 'Tell Me Another' the other day about his time in the Navy. (Programme from the 1970s repeated on TalkingPictures)
                                          Pertwee served on HMS Hood where the Seamen's Heads were at the front. He quickly learned that using the heads on a fast battle-cruiser in rough weather required judgement. The plumbing backed up spectacularly whenever the bow ploughed into a wave…
                                          Chris Trice
                                            @christrice43267
                                            "200 litres of sea water per hour". I would think waves and rainwater would far exceed that figure in bad weather.
                                            #332793
                                            Crocadillopig
                                              @crocadillopig
                                              Although It doesn't sound critical and can be easily fixed it could be expensive if she has to dock down and de-store to repair. I remember being deployed on the Invincible when The propeller shaft 'A' bracket bearing needed replacing it took several attempts to fix in dry dock. Nearest place was Singapore (Oh what a Shame)smiley
                                              Russ
                                              #332799
                                              ChrisH
                                                @chrish
                                                In the merchant navy they years ago gave away the idea of a wood lined tube, lubricated by sea water, sealed by a packed gland to keep most of the sea outside the ship, to support the prop shaft as it exited the ship. They were replaced with (very well) sealed tubes containing a totally oil filled bearing under a considerable head of oil. Therefore absolutely no sea water through it at all. If sea water was leaking through that shaft bearing and seal you were definitely in the mire! Hope this is not the case here but suspect so.
                                                Chris
                                                #332814
                                                  Does that include me…?
                                                  N.
                                                  #332829
                                                  doubletop
                                                    @doubletop
                                                    Its undergoing sea trials, which is about testing all the systems.
                                                    After being told many times in the RAF, "just get it tested and flying again". I'd point out that the main purpose of testing was to find out what isn't working, not necessarily to find out what is working. Therefore, the assumption must be something could be wrong that will require fixing, which will take time.
                                                    In fact, if you test something and don't find a problem you must seriously consider if your test plan is flawed.
                                                    So the Navy have been testing and found a problem. Good job!! Now a case of doing the risk analysis, and deciding whether to fix the seal, re-design and fix all the other seals as well, install bigger pumps, monitor or just ignore.
                                                    Pete
                                                    #332832
                                                      @mike89748
                                                      No, it doesn't include you, Neil. Just looked you up on Linkedin – what an interesting career!
