My Bosch washing machine is working fine, but it has a loud, harsh, high pitched whine, which varies with the motor speed. It isn’t motor or drum bearings as I have checked these out. I strongly suspect that there is a component which is vibrating in the motor inverter circuit.
Not being a washing machine expert, is this a likely explanation? If it is a possibility, I would like to find the component before it fails! Are there any other likely explanations for this weird sound?
Andrew.
