I use wood as a material in both my modelling and workshop projects. I'm currently building a stand for my Aldi metal bandsaw, as I think it will be most useful in vertical mode. Most stand versions I've seen use metal frames but I had some suitable pine offcuts and being quick to cut and join – I decided it was a good solution for this job.
However, my tin of wood primer had 'expired' and passing Robert Dyas yesterday, I popped in for a replacement tin. I was very surprised to find that a 750ml tin of Dulux wood primer was £21.45!
I had to get up real close to read the small print to check that I was reading the right product label.
Fortunately, a 750ml tin of Berger wood primer ( "quality paints since 1760" ) was also available at £8.99 – which suited my pocket much better. I will admit that it does seem a bit thinner than I remember the Dulux primer being – but I don't need an undercoat as such, just a primer to seal the wood.
I guess time will tell how good the Berger primer actually is but assuming it does the job, I won't be tempted back to Dulux any time soon – not as those prices anyway…
IanT
