Hi Rod;
I've made it, but not used it much.
I think that you'll find that the accuracy is in the setup; all it really does is hold a toolbit and allow you to move it in a circle of about 180 degrees. Fine feed is by the screw on the back of the tool holder.
I should use it more; work and family stuff has got between me and my workshop recently – so the lack of use is not a black mark on the tool design.
I made my semi-circular table on my smaller CNC mill, out of brass, 1/8" thick. Also made the tool holder slider (that slides on the semi-circular table) out of brass on my CNC mill, also.
