Help With Broken Connection
Home Forums Electronics in the Workshop Help With Broken Connection
  • #31943
    “Bill Hancox”
      @billhancox
      227 IEC 53(RVV) wire core
      #349880
      “Bill Hancox”
        @billhancox
        Today I attempted to repair a broken electrical connection on a 227 IEC 53(RVV) power cable. The spade connector has broken off for some reason. When I attempted to strip the wire back with a wire stripping tool it the core fell apart in a small cloud of grayish colored powder. There is a very fine stranded copper core that seems to be encased in some sort of clay type jacket that falls apart at the slightest touch. The broken off connector appears to be a standard spade connector. Does this cable require that I use a special type of spade connector or is there a secret to stripping it? Any help or advice would be appreciated. The wire serves a high heat application.
        Bill
        #349888
        David George 1
          @davidgeorge1
          Hi Bill the cable is I believe faulty it has passed its best and lost its flexibility. I would replace it with a pfa and glass fibre insulated cable which is what I use in furnaces and hot use mould tooling up to 250 degree temp. R S components are one seller.
          David
          #349903
          Ian P
            @ianp
            What is a 227 IEC 53 (RVV)?
            Your description of the cable seems to indicate that it is some type designed for high temperature operation (mineral filled?) so probably does need special termination equipment and connector.
            Why not just get a replacement cable and be certain.
            Ian P
            #349907
              Posted by Ian P on 12/04/2018 09:23:13:
              It appears to be a common [PVC] 3-core flex: **LINK**
              http://www.wellshin.com.tw/en/mod/product/index.php?REQUEST_ID=246dfb750606ad892550bde28048718e2e7d5347ea00f14737e89c54a8a8ed56
              https://senhall.en.made-in-china.com/product/QvOJIjzyhEcT/China-Power-Cord-227-IEC-53-RVV-300-500V-.html
              Edited By Michael Gilligan on 12/04/2018 09:56:32
              #349922
              Ian P
                @ianp
                I ruled out it being a standard IEC type kettle lead because of it having 'standard' spade connectors (whatever those are). If one end of this cable has a 13A plug then I would expect some sort of female termination.
                I suppose the greyish powder could be decomposed plastic insulation but I dont think I have ever seen a heat damaged cable turn to dust.
                There are 'hot condition' IEC ready made moulded cable assemblies available maybe that would be the simplest solution.
                Ian P
                #349932
                  If it has a notch below the earth socket on the IEC plug it's a high temperature version as used for kettles etc.
                  These also fit normal sockets but standard IEC plugs won't fit a high temperature socket as these have a raised piece to engage the notch.
                  en.wikipedia.org/w/index.php?title=IEC_60320&action=edit&section=7
                  Edited By Neil Wyatt on 12/04/2018 11:20:35
                  #349956
                    Posted by Michael Gilligan on 12/04/2018 09:55:18:
                    For clarity, I should mention that both of the links I posted refer to 'by the metre' flex, rated for modest temperatures … I see no reference to 'made-up' cables, or to high-temperature rating.
                    Edited By Michael Gilligan on 12/04/2018 14:03:57
