Help with an ML7 dimension.
Home Forums General Questions Help with an ML7 dimension.
  • #607128
    Andrew Tinsley
      @andrewtinsley63637
      I will not be able to measure up my ML7 for a few weeks. So can anyone tell me the height of the lathe center to the topslide flat?
      I need it for some design calculations.
      Thanks in advance,
      Andrew.
      Andrew Tinsley
        @andrewtinsley63637
        #607134
        Trevor Drabble 1
          @trevordrabble1
          According to lathes.co web site , 4" dia swing , so 2" to centre height.
          #607137
          Grindstone Cowboy
            @grindstonecowboy
            Just to clarify before I go and measure, do you want height from the top surface of the compound slide (i.e. where the tool would sit if you still used the original toolholder) or from the T-slotted surface of the cross-slide?
            I could always measure both…. blush
            Rob
            #607139
            DiogenesII
              @diogenesii
              ..nominally 5/8 / 15.88mm, – individual machines might be +/- a thou or two.. ..unless reground, all bets off in that case!
              Edited By DiogenesII on 24/07/2022 12:54:25
              #607144
              Grindstone Cowboy
                @grindstonecowboy
                As Trevor and Diogenes have said, cross-slide to centre 2" (2.071" ) and top of compound to centre 0.625" (0.629" ) – my measurements in brackets.
                Rob
                Edited for errant emoticons
                Edited By Grindstone Cowboy on 24/07/2022 13:51:00
                #607147
                Swarf, Mostly!
                  @swarfmostly
                  I offer this in the hope it will help:
                  I cribbed it from G.H.Thomas' book – he recommended that we each maintain a version of this diagram corrected to show our own 'as-fitted' dimensions.
                  Best regards,
                  Swarf, Mostly!
                  #607162
                  Andrew Tinsley
                    @andrewtinsley63637
                    Hello Folks that is great, just to clarify, it was centre height of lathe to the flat surface of the topslide (where the tool would sit.
                    Looks as though 5/8" is the answer plus a bed regrind!
                    Thanks to everyone for the help.
                    Andrew.
